【错误记录】编译 Linux 内核报错 ( /bin/sh: 1: bison: not found )
韩曙亮 发表于 2022/03/24 23:47:02 2022/03/24
【摘要】 文章目录 一、报错信息二、解决方案 一、报错信息 编译 Linux 内核 , 执行 make menuconfig 1 配置菜单命令 , 报如下错误 : ro...
一、报错信息
编译 Linux 内核 , 执行
make menuconfig
配置菜单命令 , 报如下错误 :
root@ubuntu:~/kernel/linux-5.6.14# make menuconfig
  LEX     scripts/kconfig/lexer.lex.c
  YACC    scripts/kconfig/parser.tab.[ch]
scripts/Makefile.host:17: recipe for target 'scripts/kconfig/parser.tab.h' failed
make[1]: *** [scripts/kconfig/parser.tab.h] Error 127
Makefile:568: recipe for target 'menuconfig' failed
make: *** [menuconfig] Error 2
二、解决方案
执行
sudo apt-get install bison
命令 , 安装 bison ;
安装过程如下 :
root@ubuntu:~/kernel/linux-5.6.14# sudo apt-get install bison -y
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  libbison-dev
Suggested packages:
  bison-doc
The following NEW packages will be installed:
  bison libbison-dev
0 upgraded, 2 newly installed, 0 to remove and 154 not upgraded.
Need to get 597 kB of archives.
After this operation, 1,795 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 libbison-dev amd64 2:3.0.4.dfsg-1 [338 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 bison amd64 2:3.0.4.dfsg-1 [259 kB]
Fetched 597 kB in 2s (252 kB/s)
Selecting previously unselected package libbison-dev:amd64.
(Reading database ... 212318 files and directories currently installed.)
Preparing to unpack .../libbison-dev_2%3a3.0.4.dfsg-1_amd64.deb ...
Unpacking libbison-dev:amd64 (2:3.0.4.dfsg-1) ...
Selecting previously unselected package bison.
Preparing to unpack .../bison_2%3a3.0.4.dfsg-1_amd64.deb ...
Unpacking bison (2:3.0.4.dfsg-1) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up libbison-dev:amd64 (2:3.0.4.dfsg-1) ...
Setting up bison (2:3.0.4.dfsg-1) ...
update-alternatives: using /usr/bin/bison.yacc to provide /usr/bin/yacc (yacc) in auto mode
  • 26
  • 27
  • 28
原文链接:hanshuliang.blog.csdn.net/article/details/123656486
