项目中如何优雅的消除if-else
琴岛蛏子 发表于 2022/03/21 00:08:19 2022/03/21
【摘要】 项目中如何优雅的消除if-else消除if-else的方法有很多种,本文结合spring中ArgumentResolver的应用,提供一种优雅地方式。先看ArgumentResolver的应用方式public class UserArgumentResolver implements HandlerMethodArgumentResolver { private static final...
项目中如何优雅的消除if-else
  private static final String TOKEN_KEY = "token";
  @Override
  public boolean supportsParameter(MethodParameter parameter) {
      return parameter.hasParameterAnnotation(LoginUser.class);
  @Override
  public Object resolveArgument(MethodParameter parameter,
                                ModelAndViewContainer mavContainer,
                                NativeWebRequest webRequest,
                                WebDataBinderFactory binderFactory) throws Exception {
      // 通过session取userid
      String token = webRequest.getHeader(TOKEN_KEY);
      User user = null;
      // 从redis中获取user json
      // user  = JSON.parse(redis.get(token),User.class);
      return user;
controller 需要注入参数的地方
@RequestMapping(value = "/doSth", method = RequestMethod.POST)
public String feed(@LoginUser User user) {
  System.out.println("userId: " + JSON.toJsonString(user));
  return "success";
声明注解LoginUser
@Target(ElementType.TYPE,ElementType.PARAMETER)
@Retention(RetentionPolicy.RUNTIME)
@Documented
public @interface RestController {
 String value() default "";
配置类添加
@Configuration
public class WebConfiguration implements WebMvcConfigurer {
  @Override
  public void addArgumentResolvers (List<HandlerMethodArgumentResolver> resolvers) {
    resolvers.add(new UserArgumentResolver());
有多个ArgumentResolver在WebConfiguration中配置即可。
if-else消除
常用代码 如交通方式有 bike, bus,subway,train,plan
if (bike) {
} else if (bus) {
} else if (subway) {
} else if (train) {
} else if (plan) {
}else {
编写不同的reslover
定义统一的接口
public interface TrafficResolver {
    boolean support(String type);
    Object resolver(Object argument);
定义实现类BusTrafficResolver,其他省略
@Compoment
public class BusTrafficResolver implements TrafficResolver{
  @Override
  public boolean support (String type) {
    return "BUS".equals(type);
  @Override
  public Object resolver (Object argument) {
    // doSth
    return "bus resolver";
真正消除if-else的服务类
List<TrafficResolver> 若没有bean则需要required 比提供默认值new ArrayList<>() ,有bean 可以去掉。
@Service
public class TrafficService {
  // required = false
  @Autowired(required = false)
  List<TrafficResolver> trafficResolverList = new ArrayList<>();
  public Object traffic(String type,Object argument){
    System.out.printf("trafficResolverList "+trafficResolverList.size());
    TrafficResolver resolver = getFirstResolver(type);
    if(resolver!=null){
      return resolver.resolver(argument);
    return "traffic not find. type: "+type;
  private TrafficResolver getFirstResolver(String type){
    TrafficResolver resolver = trafficResolverList.stream()
        .filter(item -> item.support(type))
        .findFirst()
        .orElse(null);
    return resolver;
通过此种方式完成了对if-else调用类的解耦,实现了高扩展性。遵循了面向修改关闭,面向扩展开放的原则。
消除if-else完成,当然可以用注解的方式,通过注解类型判断是否支持。
其实if-else挺好用,除非考虑扩展性很强的地方,否则不要过度设计。
