php实现排序功能(提供全部)
陈业贵 发表于 2022/03/19 00:46:38 2022/03/19
【摘要】 -- phpMyAdmin SQL Dump -- version 4.5.1 -- http://www.phpmyadmin.net -- -- Host: 127.0.0.1 -- Generati...
-- version 4.5.1
-- Host: 127.0.0.1
-- Generation Time: 2022-03-17 17:19:09
-- 服务器版本: 10.1.13-MariaDB
-- PHP Version: 5.6.21
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO";
SET time_zone = "+00:00";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8mb4 */;
-- Database: `a`
-- 表的结构 `search`
CREATE TABLE `search` (
  `id` int(11) NOT NULL DEFAULT '0',
  `content` text COLLATE utf8_vietnamese_ci NOT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_vietnamese_ci;
-- 转存表中的数据 `search`
INSERT INTO `search` (`id`, `content`) VALUES
(666, 'cyg'),
(2, 'liwen'),
(555, 'liwen&cyg');
/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
/*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
/*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
cyg.php
<?php
$link=mysqli_connect('localhost','root','','a');
//然后是指定php链接数据库的字符集
mysqli_set_charset($link,'utf8');
$sql="select * from search";
$result=mysqli_query($link,$sql);//运行sql
<!--显示的效果-->
<!DOCTYPE html>
<html lang="en">
<head>
	<meta charset="UTF-8">
	<title>Document</title>
</head>
<body>
	<table border="1" cellpadding="5">
		<tr>
			<td>id</td>
			<td>标题</td>
			<td>内容</td>
		<?php
			while ($row=mysqli_fetch_array($result)) {//把对象编程数组输出,不然会报错哦
		<tr>
			<td><?=$row['id'];?></td>
			<td><?=$row['content'];?></td>
		</tr>
		<?php
		<td><a href="create.php">创建才能排序哦</a></td>
			<td><a href="asc.php">升序</a></td><!--从小到大-->
			<td><a href="desc.php">降序</a></td><!--从大到小-->
		</tr>
	</table>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
create.php
<!DOCTYPE html>
<html lang="en">
<head>
</head>
<body>
	<form action="create.php" method="POST">
	<input type="text" name="id">
		<input type="text" name="content">
		<input type="submit" value="提交">
	</form>
</body>
</html>
<?php
if(!$_POST['content']||!$_POST['id'])
exit();
$content=$_POST['content'];
$id=$_POST['id'];
//然后是指定php链接数据库的字符集
$sql = "INSERT INTO search(id,content)
VALUES ('{$id}','{$content}')";
echo "<script>alert('创建成功');</script>";
<button><a href="cyg.php">返回</a></button>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
asc:
<?php
//然后是指定php链接数据库的字符集
$sql = "SELECT id,content FROM search ORDER BY id";
<!DOCTYPE html>
<html lang="en">
<head>
</head>
<body>
		<tr>
			<td>id</td>
			<td>标题</td>
			<td>内容</td>
		<?php
		<tr>
		</tr>
		<?php
		</tr>
	</table>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
desc.php
<?php
//然后是指定php链接数据库的字符集
$sql = "SELECT id,content FROM search ORDER BY id desc";
<!DOCTYPE html>
<html lang="en">
<head>
</head>
<body>
		<tr>
			<td>id</td>
			<td>标题</td>
			<td>内容</td>
		<?php
		<tr>
		</tr>
		<?php
		</tr>
	</table>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
文章来源: blog.csdn.net,作者:贵哥的编程之路(热爱分享),版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_37805832/article/details/123564366
