MongoDB 第12章 性能监控
许小强 发表于 2022/03/18 17:19:51 2022/03/18
【摘要】 性能监控
1、MongoStat
此工具可以快速的查看某组运行中的MongoDB实例的统计信息,用法如下:
[root@localhost bin]# ./mongostat
connected to: 127.0.0.1
insert  query update delete getmore command flushes mapped  vsize    res faults     locked db idx miss %     qr|qw   ar|aw  netIn netOut  conn       time
    *0     *0     *0     *0       0     1|0       0   320m   939m    37m      1 zhangsan:0.1%          0       0|0     0|0    62b     3k     2   21:49:23
    *0     *0     *0     *0       0     1|0       0   320m   939m    37m      0 zhangsan:0.0%          0       0|0     0|0    62b     3k     2   21:49:24
    *0     *0     *0     *0       0     1|0       0   320m   939m    37m      0 zhangsan:0.0%          0       0|0     0|0    62b     3k     2   21:49:25
    *0     *0     *0     *0       0     1|0       0   320m   939m    37m      0 zhangsan:0.0%          0       0|0     0|0    62b     3k     2   21:49:26
字段说明:
insert每秒插入量
query每秒查询量
update每秒更新量
delete每秒删除量
locked锁定量
qr|qw客户端查询排队长度(读|写)
ar|aw活跃客户端量(读|写)
conn连接数
time当前时间
它每秒中刷新一次状态值,提供良好的可读性,通过这些参数可以观察到一个整体的性能情况。
2、db.serverStatus
这个命令是最常用也是最基础的查看实例运行状态的命令之一,下面我们看一下它的输出:
> db.serverStatus()
        "host" : "localhost.localdomain",
        "version" : "2.6.6", --服务器版本
        "process" : "mongod",
        "pid" : NumberLong(29293),
        "uptime" : 23180,--启动时间(秒)
        "uptimeMillis" : NumberLong(23179942),
        "uptimeEstimate" : 21041,
        "localTime" : ISODate("2015-01-04T13:53:03.792Z"),
        "asserts" : {
                "regular" : 0,
                "warning" : 0,
                "msg" : 0,
                "user" : 0,
                "rollovers" : 0
        "backgroundFlushing" : {
                "flushes" : 386,
                "total_ms" : 99,
                "average_ms" : 0.25647668393782386,
                "last_ms" : 0,
                "last_finished" : ISODate("2015-01-04T13:52:44.259Z")
        "connections" : {
                "current" : 2,--当前活动连接量
                "available" : 817,--剩余空闲连接量
                "totalCreated" : NumberLong(19)
        "cursors" : {
                "note" : "deprecated, use server status metrics",
                "clientCursors_size" : 0,
                "totalOpen" : 0,
                "pinned" : 0,
                "totalNoTimeout" : 0,
                "timedOut" : 0
        "dur" : {
                "commits" : 29,
                "journaledMB" : 0,
                "writeToDataFilesMB" : 0,
                "compression" : 0,
                "commitsInWriteLock" : 0,
                "earlyCommits" : 0,
                "timeMs" : {
                        "dt" : 3038,
                        "prepLogBuffer" : 0,
                        "writeToJournal" : 0,
                        "writeToDataFiles" : 0,
                        "remapPrivateView" : 0
        "extra_info" : {
                "note" : "fields vary by platform",
                "heap_usage_bytes" : 62803792,
                "page_faults" : 36
        "globalLock" : {
                "totalTime" : NumberLong("23179943000"),
                "lockTime" : NumberLong(3334379),
                "currentQueue" : {
                        "total" : 0,--当前全部队列量
                        "readers" : 0,--读请求队列量
                        "writers" : 0--写请求队列量
                "activeClients" : {
                        "total" : 0,--当前全部客户端连接量
                        "readers" : 0,--客户端读请求量
                        "writers" : 0--客户端写请求量
        "indexCounters" : {
                "accesses" : 38,--索引被访问量
                "hits" : 38,--索引命中量
                "misses" : 0,--索引偏差两
                "resets" : 0,
                "missRatio" : 0--索引偏差率(未命中率)
        "locks" : {
                        "timeLockedMicros" : {
                                "R" : NumberLong(954466),
                                "W" : NumberLong(3334379)
                        "timeAcquiringMicros" : {
                                "R" : NumberLong(5652043),
                                "W" : NumberLong(133798)
                "admin" : {
                                "r" : NumberLong(255071),
                                "w" : NumberLong(0)
                                "r" : NumberLong(67318),
                                "w" : NumberLong(0)
                "local" : {
                                "r" : NumberLong(82150),
                                "w" : NumberLong(17)
                                "r" : NumberLong(18964),
                                "w" : NumberLong(1)
                "zhangsan" : {
                                "r" : NumberLong(8788),
                                "w" : NumberLong(1673999)
                                "r" : NumberLong(1409),
                                "w" : NumberLong(55)
                "temp" : {
                                "r" : NumberLong(340424),
                                "w" : NumberLong(2765621)
                                "r" : NumberLong(111659),
                                "w" : NumberLong(6212)
                "test" : {
                                "r" : NumberLong(602182),
                                "w" : NumberLong(437948)
                                "r" : NumberLong(73084),
                                "w" : NumberLong(85)
        "network" : {
                "bytesIn" : 66494,--发给此服务器的数据量(单位:byte)
                "bytesOut" : 865147,--此服务器发出的数据量(单位:byte)
                "numRequests" : 851--发给此服务器的请求量
        "opcounters" : {
                "insert" : 9,--插入操作的量
                "query" : 1928,--查询操作的量
                "update" : 8,--更新操作的量
                "delete" : 2,
                "getmore" : 0,
                "command" : 812--其他操作的量
        "opcountersRepl" : {
                "insert" : 0,
                "query" : 0,
                "update" : 0,
                "delete" : 0,
                "getmore" : 0,
                "command" : 0
        "recordStats" : {
                "accessesNotInMemory" : 0,
                "pageFaultExceptionsThrown" : 0,
                "admin" : {
                "local" : {
                "temp" : {
                "test" : {
                "zhangsan" : {
        "writeBacksQueued" : false,
        "mem" : {
                "bits" : 64,--64位系统
                "resident" : 37,--占用物理内存量
                "virtual" : 939,--虚拟内存量
                "supported" : true,--是否支持扩展内存
                "mapped" : 320,
                "mappedWithJournal" : 640
        "metrics" : {
                "cursor" : {
                        "timedOut" : NumberLong(0),
                        "open" : {
                                "noTimeout" : NumberLong(0),
                                "pinned" : NumberLong(0),
                                "total" : NumberLong(0)
                "document" : {
                        "deleted" : NumberLong(1),
                        "inserted" : NumberLong(9),
                        "returned" : NumberLong(428),
                        "updated" : NumberLong(8)
                "getLastError" : {
                        "wtime" : {
                                "num" : 0,
                                "totalMillis" : 0
                        "wtimeouts" : NumberLong(0)
                "operation" : {
                        "fastmod" : NumberLong(1),
                        "idhack" : NumberLong(0),
                        "scanAndOrder" : NumberLong(0)
                "queryExecutor" : {
                        "scanned" : NumberLong(2),
                        "scannedObjects" : NumberLong(2)
                "record" : {
                        "moves" : NumberLong(0)
                "repl" : {
                        "apply" : {
                                "batches" : {
                                        "num" : 0,
                                        "totalMillis" : 0
                                "ops" : NumberLong(0)
                        "buffer" : {
                                "count" : NumberLong(0),
                                "maxSizeBytes" : 268435456,
                                "sizeBytes" : NumberLong(0)
                        "network" : {
                                "bytes" : NumberLong(0),
                                "getmores" : {
                                        "num" : 0,
                                        "totalMillis" : 0
                                "ops" : NumberLong(0),
                                "readersCreated" : NumberLong(0)
                        "preload" : {
                                "docs" : {
                                        "num" : 0,
                                        "totalMillis" : 0
                                "indexes" : {
                                        "num" : 0,
                                        "totalMillis" : 0
                "storage" : {
                        "freelist" : {
                                "search" : {
                                        "bucketExhausted" : NumberLong(0),
                                        "requests" : NumberLong(399),
                                        "scanned" : NumberLong(731)
                "ttl" : {
                        "deletedDocuments" : NumberLong(0),
                        "passes" : NumberLong(386)
        "ok" : 1
3、db.stats
db.stats查看数据库状态信息,使用样例如下:
> db.stats()
        "db" : "test",
        "collections" : 16,--collection数量
        "objects" : 152,--对象数量
        "avgObjSize" : 72.42105263157895,--对象平均大小
        "dataSize" : 11008,--数据大小
        "storageSize" : 131072,--数据大小(含预分配空间)
        "numExtents" : 16,--事件数量
        "indexes" : 20,--索引数量
        "indexSize" : 163520,--索引文件大小
        "fileSize" : 67108864,--文件大小
        "nsSizeMB" : 16,
        "dataFileVersion" : {
                "major" : 4,
                "minor" : 5
        "extentFreeList" : {
                "num" : 1,
                "totalSize" : 131072
        "ok" : 1--本次取stats是否正常
通过这个工具,可以查看当前数据库的基本信息。
4、第三方工具
MongoDB从一面世就得到了众多开源爱好者和团队的重视,在常用的监控框架如cacti、Nagios、Zabbix等基础上进行扩展,进行MongoDB的监控都是非常方便的。
