高德地图JS--批量规划步行路线 优化
拿我格子衫来 发表于 2022/03/17 23:49:23 2022/03/17
【摘要】 调取高德地图JS API 进行步行路线规划 多个起点到达一个重点,根据搜素结果画路线,进行绘图,并为线路添加点击事件 效果如下: 代码如下: <!doctype html><html><head> <meta charset="utf-8"> <meta ht...
效果如下:
代码如下:
  1. <!doctype html>
  2. <html>
  3. <head>
  4. <meta charset="utf-8">
  5. <meta http-equiv="X-UA-Compatible" content="IE=edge">
  6. <meta name="viewport" content="initial-scale=1.0, user-scalable=no, width=device-width">
  7. <style>
  8. html,
  9. body,
  10. #container {
  11. width: 100%;
  12. height: 100%;
  13. }
  14. </style>
  15. <title>根据规划数据绘制步行路线</title>
  16. <link rel="stylesheet" href="https://a.amap.com/jsapi_demos/static/demo-center/css/demo-center.css"/>
  17. <script src="https://webapi.amap.com/maps?v=1.4.10&key=d799a2887868628bf7782fcd6b2c0ed1&plugin=AMap.PolyEditor"></script>
  18. <script src="https://webapi.amap.com/maps?v=1.4.10&key=d799a2887868628bf7782fcd6b2c0ed1&plugin=AMap.Walking"></script>
  19. <script src="https://a.amap.com/jsapi_demos/static/demo-center/js/demoutils.js"></script>
  20. </head>
  21. <body>
  22. <div id="container"></div>
  23. <script type="text/javascript">
  24. var map = new AMap.Map('container', {
  25. center: [116.397559, 39.89621],
  26. zoom: 14
  27. })
  28. // 当前示例的目标是展示如何根据规划结果绘制路线,因此walkOption为空对象
  29. var walkingOption = {}
  30. let dataArr = [
  31. [15, '汽车服务', 116.807599, 39.6462117, 1.459, 6.3265],
  32. [22, '汽车服务', 117.6136484, 39.7657742, 9.738, 7.5687],
  33. [30, '汽车服务', 117.2940413, 39.7878749, 7.7227, 6.5476],
  34. [37, '汽车服务', 116.0684453, 38.174566, 4.5352, 8.5357],
  35. [42, '汽车服务', 117.3493731, 38.6404797, 1.1438, 4.3265],
  36. [43, '汽车服务', 116.8465287, 38.363796, 8.7718, 4.4577]]
  37. let targetPoint = [116.944964, 39.457521]
  38. // 搜素路线的函数
  39. function searchRouter (startPointArr, endPoint) {
  40. for (let i = 0; i < startPointArr.length; i++) {
  41. let item = startPointArr[i]
  42. let startPoint = [item[2], item[3]]
  43. // 步行导航
  44. var walking = new AMap.Walking(walkingOption)
  45. //根据起终点坐标规划步行路线
  46. walking.search(startPoint, endPoint, function (status, result) {
  47. // result即是对应的步行路线数据信息,相关数据结构文档请参考 https://lbs.amap.com/api/javascript-api/reference/route-search#m_WalkingResult
  48. if (status === 'complete') {
  49. if (result.routes && result.routes.length) {
  50. drawRoute(result.routes[0], item)
  51. log.success('绘制步行路线完成')
  52. }
  53. } else {
  54. log.error('步行路线数据查询失败' + result)
  55. }
  56. })
  57. }
  58. }
  59. // 描绘路线的函数
  60. function drawRoute (route, item) {
  61. var path = parseRouteToPath(route)
  62. var startMarker = new AMap.Marker({
  63. position: path[0],
  64. icon: 'https://webapi.amap.com/theme/v1.3/markers/n/start.png',
  65. map: map
  66. })
  67. var endMarker = new AMap.Marker({
  68. position: path[path.length - 1],
  69. icon: 'https://webapi.amap.com/theme/v1.3/markers/n/end.png',
  70. map: map
  71. })
  72. var routeLine = new AMap.Polyline({
  73. path: path,
  74. isOutline: true,
  75. outlineColor: '#ffeeee',
  76. borderWeight: 2,
  77. strokeWeight: 5,
  78. cursor: 'pointer',
  79. strokeColor: '#0091ff',
  80. lineJoin: 'round',
  81. extData: item
  82. })
  83. routeLine.on('click', function (obj) {
  84. console.log(obj.target.getExtData())
  85. alert('您点击了线为' + obj.target.getExtData().toString())
  86. })
  87. routeLine.setMap(map)
  88. // 调整视野达到最佳显示区域
  89. map.setFitView([startMarker, endMarker, routeLine])
  90. }
  91. // 解析WalkRoute对象,构造成AMap.Polyline的path参数需要的格式
  92. // WalkRoute对象的结构文档 https://lbs.amap.com/api/javascript-api/reference/route-search#m_WalkRoute
  93. function parseRouteToPath (route) {
  94. var path = []
  95. for (var i = 0, l = route.steps.length; i < l; i++) {
  96. var step = route.steps[i]
  97. path.push([step.start_location.lng, step.start_location.lat])
  98. path.push([step.end_location.lng, step.end_location.lat])
  99. }
  100. return path
  101. }
  102. searchRouter(dataArr, targetPoint)
  103. </script>
  104. </body>
  105. </html>
有任何高德JS API 调用问题都可以在下方评论咨询我。博主做过很多O2O示例
谢谢阅读.如果觉得对你有帮助请记得点赞或收藏.欢迎留言讨论.你的支持是我出产优秀博客的动力.
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/82888621
