gitlab runner The Docker executor
The Docker executor
GitLab Runner can use Docker to run jobs on user provided images. This is
possible with the use of Docker executor.
The Docker executor when used with GitLab CI, connects to Docker Engine
and runs each build in a separate and isolated container using the predefined
image that is set up in .gitlab-ci.yml and in accordance in
config.toml.
That way you can have a simple and reproducible build environment that can also
run on your workstation. The added benefit is that you can test all the
commands that we will explore later from your shell, rather than having to test
them on a dedicated CI server.
The following configurations are supported:
| Runner is installed on: | Executor is: | Container is running: |
| Windows | docker-windows |
Windows |
| Windows | docker |
Linux |
| Linux | docker |
Linux |
These configurations are not supported:
| Linux | docker-windows |
Linux |
| Linux | docker |
Windows |
Windows |
| Windows | docker |
Windows |
Linux |
NOTE:
GitLab Runner uses Docker Engine API
v1.25 to talk to the Docker
Engine. This means the
minimum supported version
of Docker on a Linux server is 1.13.0,
on Windows Server it needs to be more recent
to identify the Windows Server version.
Using Windows containers
Introduced in GitLab Runner 11.11.
To use Windows containers with the Docker executor, note the following
information about limitations, supported Windows versions, and
configuring a Windows Docker executor.
Nanoserver support
Introduced in GitLab Runner 13.6.
With the support for Powershell Core introduced in the Windows helper image, it is now possible to leverage
the nanoserver variants for the helper image.
Limitations
The following are some limitations of using Windows containers with
Docker executor:
Docker-in-Docker is not supported, since it’s not
supported by
Docker itself. -
Interactive web terminals are not supported.
Host device mounting not supported.
When mounting a volume directory it has to exist, or Docker will fail
to start the container, see
#3754 for
additional detail. -
docker-windowsexecutor can be run only using GitLab Runner running
on Windows. -
Linux containers on
Windows
are not supported, since they are still experimental. Read the
relevant
issue for
more details. -
Because of a limitation in
Docker,
if the destination path drive letter is notc:, paths are not supported for:This means values such as
f:\\cache_dirare not supported, butf:is supported.
However, if the destination path is on thec:drive, paths are also supported
(for examplec:\\cache_dir).
Supported Windows versions
GitLab Runner only supports the following versions of Windows which
follows our support lifecycle for
Windows:
- Windows Server 2004.
- Windows Server 1809.
For future Windows Server versions, we have a future version support
policy.
You can only run containers based on the same OS version that the Docker
daemon is running on. For example, the following Windows Server Core images can
be used:
mcr.microsoft.com/windows/servercore:2004mcr.microsoft.com/windows/servercore:2004-amd64mcr.microsoft.com/windows/servercore:1809mcr.microsoft.com/windows/servercore:1809-amd64mcr.microsoft.com/windows/servercore:ltsc2019
Supported Docker versions
A Windows Server running GitLab Runner must be running a recent version of Docker
because GitLab Runner uses Docker to detect what version of Windows Server is running.
A known version of Docker that doesn’t work with GitLab Runner is Docker 17.06
since Docker does not identify the version of Windows Server resulting in the
following error:
unsupported Windows Version: Windows Server Datacenter
- 1
Read more about troubleshooting this.
Configuring a Windows Docker executor
NOTE:
When a runner is registered with c:\\cache
as a source directory when passing the --docker-volumes or
DOCKER_VOLUMES environment variable, there is a
known issue.
Below is an example of the configuration for a simple Docker
executor running Windows.
[[runners]]
name = "windows-docker-2019"
url = "https://gitlab.com/"
token = "xxxxxxx"
executor = "docker-windows"
[runners.docker]
image = "mcr.microsoft.com/windows/servercore:1809_amd64"
volumes = ["c:\\cache"]
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
For other configuration options for the Docker executor, see the
advanced
configuration
section.
Services
You can use services by
enabling network per-build networking mode.
Available
since GitLab Runner 12.9.
Workflow
The Docker executor divides the job into multiple steps:
- Prepare: Create and start the services.
- Pre-job: Clone, restore cache
and download artifacts from previous
stages. This is run on a special Docker image. - Job: User build. This is run on the user-provided Docker image.
- Post-job: Create cache, upload artifacts to GitLab. This is run on
a special Docker Image.
The special Docker image is based on Alpine Linux and contains all the tools
required to run the prepare, pre-job, and post-job steps, like the Git and the
GitLab Runner binaries for supporting caching and artifacts. You can find the definition of
this special image in the official GitLab Runner repository.
The image keyword
The image keyword is the name of the Docker image that is present in the
local Docker Engine (list all images with docker images) or any image that
can be found at Docker Hub. For more information about images and Docker
Hub please read the Docker Fundamentals documentation.
In short, with image we refer to the Docker image, which will be used to
create a container on which your build will run.
If you don’t specify the namespace, Docker implies library which includes all
official images. That’s why you’ll see
many times the library part omitted in .gitlab-ci.yml and config.toml.
For example you can define an image like image: ruby:2.6, which is a shortcut
for image: library/ruby:2.6.
Then, for each Docker image there are tags, denoting the version of the image.
These are defined with a colon (:) after the image name. For example, for
Ruby you can see the supported tags at https://hub.docker.com/_/ruby/. If you
don’t specify a tag (like image: ruby), latest is implied.
The image you choose to run your build in via image directive must have a
working shell in its operating system PATH. Supported shells are sh,
bash, and pwsh (since 13.9)
for Linux, and PowerShell for Windows.
GitLab Runner cannot execute a command using the underlying OS system calls
(such as exec).
The services keyword
The services keyword defines just another Docker image that is run during
your build and is linked to the Docker image that the image keyword defines.
This allows you to access the service image during build time.
The service image can run any application, but the most common use case is to
run a database container, e.g., mysql. It’s easier and faster to use an
existing image and run it as an additional container than install mysql every
time the project is built.
You can see some widely used services examples in the relevant documentation of
CI services examples.
If needed, you can assign an alias
to each service.
Networking
Networking is required to connect services to the build job and may also be used to run build jobs in user-defined
networks. Either legacy network_mode or per-build networking may be used.
Legacy container links
The default network mode uses Legacy container links with
the default Docker bridge mode to link the job container with the services.
network_mode can be used to configure how the networking stack is set up for the containers
using one of the following values:
- One of the standard Docker networking modes:
bridge: use the bridge network (default)host: use the host’s network stack inside the containernone: no networking (not recommended)- Any other
network_modevalue is taken as the name of an already existing
Docker network, which the build container should connect to.
For name resolution to work, Docker will manipulate the /etc/hosts file in the build
job container to include the service container hostname (and alias). However,
the service container will not be able to resolve the build job container
name. To achieve that, use the per-build network mode.
Linked containers share their environment variables.
Network per-build
Introduced in GitLab Runner 12.9.
This mode will create and use a new user-defined Docker bridge network per build.
User-defined bridge networks are covered in detail in the Docker documentation.
Unlike legacy container links used in other network modes,
Docker environment variables are not shared across the containers.
Docker networks may conflict with other networks on the host, including other Docker networks,
if the CIDR ranges are already in use. The default Docker address pool can be configured
via default-address-pool in dockerd.
To enable this mode you need to enable the FF_NETWORK_PER_BUILD
feature flag.
When a job starts, a bridge network is created (similarly to docker network create <network>). Upon creation, the service container(s) and the
build job container are connected to this network.
Both the build job container, and the service container(s) will be able to
resolve each other’s hostnames (and aliases). This functionality is
provided by Docker.
The build container is resolvable via the build alias as well as it’s GitLab assigned hostname.
The network is removed at the end of the build job.
Define image and services from .gitlab-ci.yml
You can simply define an image that will be used for all jobs and a list of
services that you want to use during build time.
image: ruby:2.6
services:
- postgres:9.3
before_script:
- bundle install
test:
script:
- bundle exec rake spec
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
It is also possible to define different images and services per job:
before_script:
- bundle install
test:2.6:
image: ruby:2.6
services:
- postgres:9.3
script:
test:2.7:
image: ruby:2.7
services:
- postgres:9.4
script:
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
Define image and services in config.toml
Look for the [runners.docker] section:
[runners.docker]
image = "ruby:2.6"
[[runners.docker.services]]
name = "mysql:latest"
alias = "db"
name = "redis:latest"
alias = "cache"
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
The example above uses the array of tables syntax.
The image and services defined this way will be added to all builds run by
that runner, so even if you don’t define an image inside .gitlab-ci.yml,
the one defined in config.toml will be used.
Define an image from a private Docker registry
Starting with GitLab Runner 0.6.0, you are able to define images located to
private registries that could also require authentication.
All you have to do is be explicit on the image definition in .gitlab-ci.yml.
image: my.registry.tld:5000/namepace/image:tag
- 1
In the example above, GitLab Runner will look at my.registry.tld:5000 for the
image namespace/image:tag.
If the repository is private you need to authenticate your GitLab Runner in the
registry. Read more on using a private Docker registry.
Accessing the services
Let’s say that you need a Wordpress instance to test some API integration with
your application.
You can then use for example the tutum/wordpress as a service image in your
.gitlab-ci.yml:
services:
- tutum/wordpress:latest
- 1
- 2
When the build is run, tutum/wordpress will be started first and you will have
access to it from your build container under the hostname tutum__wordpress
and tutum-wordpress.
The GitLab Runner creates two alias hostnames for the service that you can use
alternatively. The aliases are taken from the image name following these rules:
- Everything after
:is stripped. - For the first alias, the slash (
/) is replaced with double underscores (__). - For the second alias, the slash (
/) is replaced with a single dash (-).
Using a private service image will strip any port given and apply the rules as
described above. A service registry.gitlab-wp.com:4999/tutum/wordpress will
result in hostname registry.gitlab-wp.com__tutum__wordpress and
registry.gitlab-wp.com-tutum-wordpress.
Configuring services
Many services accept environment variables which allow you to easily change
database names or set account names depending on the environment.
GitLab Runner 0.5.0 and up passes all YAML-defined variables to the created
service containers.
For all possible configuration variables check the documentation of each image
provided in their corresponding Docker Hub page.
All variables are passed to all services containers. It’s not designed to
distinguish which variable should go where.
Secure variables are only passed to the build container.
Mounting a directory in RAM
You can mount a path in RAM using tmpfs. This can speed up the time required to test if there is a lot of I/O related work, such as with databases.
If you use the tmpfs and services_tmpfs options in the runner configuration, you can specify multiple paths, each with its own options. See the Docker reference for details.
This is an example config.toml to mount the data directory for the official Mysql container in RAM.
[runners.docker]
# For the main container
[runners.docker.tmpfs]
"/var/lib/mysql" = "rw,noexec"
# For services
[runners.docker.services_tmpfs]
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
Build directory in service
Since version 1.5 GitLab Runner mounts a /builds directory to all shared services.
See an issue: https://gitlab.com/gitlab-org/gitlab-runner/-/issues/1520.
PostgreSQL service example
See the specific documentation for
using PostgreSQL as a service.
MySQL service example
using MySQL as a service.
The services health check
After the service is started, GitLab Runner waits some time for the service to
be responsive. Currently, the Docker executor tries to open a TCP connection to
the first exposed service in the service container.
You can see how it is implemented by checking this Go command.
The builds and cache storage
The Docker executor by default stores all builds in
/builds/<namespace>/<project-name> and all caches in /cache (inside the
container).
You can overwrite the /builds and /cache directories by defining the
builds_dir and cache_dir options under the [[runners]] section in
config.toml. This will modify where the data are stored inside the container.
If you modify the /cache storage path, you also need to make sure to mark this
directory as persistent by defining it in volumes = ["/my/cache/"] under the
[runners.docker] section in config.toml.
Clearing Docker cache
Introduced in GitLab Runner 13.9, all created runner resources cleaned up.
GitLab Runner provides the clear-docker-cache
script to remove old containers and volumes that can unnecessarily consume disk space.
Run clear-docker-cache regularly (using cron once per week, for example),
ensuring a balance is struck between:
- Maintaining some recent containers in the cache for performance.
- Reclaiming disk space.
clear-docker-cache can remove old or unused containers and volumes that are created by the GitLab Runner. For a list of options, run the script with help option:
clear-docker-cache help
- 1
The default option is prune-volumes which the script will remove all unused containers (both dangling and unreferenced) and volumes.
Clearing old build images
The clear-docker-cache script will not remove the Docker images as they are not tagged by the GitLab Runner. You can however confirm the space that can be reclaimed by running the script with the space option as illustrated below:
clear-docker-cache space
Show docker disk usage
TYPE TOTAL ACTIVE SIZE RECLAIMABLE
Images 14 9 1.306GB 545.8MB (41%)
Containers 19 18 115kB 0B (0%)
Local Volumes 0 0 0B 0B
Build Cache 0 0 0B 0B
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
Once you have confirmed the reclaimable space, run the docker system prune command that will remove all unused containers, networks, images (both dangling and unreferenced), and optionally, volumes that are not tagged by the GitLab Runner.
The persistent storage
The Docker executor can provide a persistent storage when running the containers.
All directories defined under volumes = will be persistent between builds.
The volumes directive supports two types of storage:
<path>- the dynamic storage. The<path>is persistent between subsequent
runs of the same concurrent job for that project. The data is attached to a
custom cache volume:runner-<short-token>-project-<id>-concurrent-<concurrency-id>-cache-<md5-of-path>.<host-path>:<path>[:<mode>]- the host-bound storage. The<path>is
bound to<host-path>on the host system. The optional<mode>can specify
that this storage is read-only or read-write (default).
The persistent storage for builds
If you make the /builds directory a host-bound storage, your builds will be stored in:
/builds/<short-token>/<concurrent-id>/<namespace>/<project-name>, where:
<short-token>is a shortened version of the Runner’s token (first 8 letters)<concurrent-id>is a unique number, identifying the local job ID on the
particular runner in context of the project
The privileged mode
The Docker executor supports a number of options that allows fine-tuning of the
build container. One of these options is the privileged mode.
Use Docker-in-Docker with privileged mode
The configured privileged flag is passed to the build container and all
services, thus allowing to easily use the Docker-in-Docker approach.
First, configure your runner (config.toml) to run in privileged mode:
[[runners]]
executor = "docker"
[runners.docker]
privileged = true
- 1
- 2
- 3
- 4
Then, make your build script (.gitlab-ci.yml) to use Docker-in-Docker
container:
image: docker:git
services:
- docker:dind
build:
script:
- docker build -t my-image .
- docker push my-image
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
The ENTRYPOINT
The Docker executor doesn’t overwrite the ENTRYPOINT of a Docker image.
That means that if your image defines the ENTRYPOINT and doesn’t allow running
scripts with CMD, the image will not work with the Docker executor.
With the use of ENTRYPOINT it is possible to create special Docker image that
would run the build script in a custom environment, or in secure mode.
You may think of creating a Docker image that uses an ENTRYPOINT that doesn’t
execute the build script, but does execute a predefined set of commands, for
example to build the Docker image from your directory. In that case, you can
run the build container in privileged mode, and make
the build environment of the runner secure.
Consider the following example:
Create a new Dockerfile:
FROM docker:dind ADD / /entrypoint.sh ENTRYPOINT ["/bin/sh", "/entrypoint.sh"]- 1
- 2
- 3
Create a bash script (
entrypoint.sh) that will be used as theENTRYPOINT:#!/bin/sh dind docker daemon --host=unix:///var/run/docker.sock \ --host=tcp://0.0.0.0:2375 \ --storage-driver=vf & docker build -t "$BUILD_IMAGE" . docker push "$BUILD_IMAGE"- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
Push the image to the Docker registry.
Run Docker executor in
privilegedmode. Inconfig.tomldefine:[[runners]] executor = "docker" [runners.docker] privileged = true- 1
- 2
- 3
- 4
In your project use the following
.gitlab-ci.yml:variables: BUILD_IMAGE: my.image build: image: my/docker-build:image script: - Dummy Script- 1
- 2
- 3
- 4
- 5
- 6
This is just one of the examples. With this approach the possibilities are
limitless.
How pull policies work
When using the docker or docker+machine executors, you can set the
pull_policy parameter in the runner config.toml file as described in the configuration docs’
Docker section.
This parameter defines how the runner works when pulling Docker images (for both image and services keywords).
You can set it to a single value, or a list of pull policies, which will be attempted in order
until an image is pulled successfully.
If you don’t set any value for the pull_policy parameter, then
the runner will use the always pull policy as the default value.
Now let’s see how these policies work.
Using the never pull policy
The never pull policy disables images pulling completely. If you set the
pull_policy parameter of a runner to never, then users will be able
to use only the images that have been manually pulled on the Docker host
the runner runs on.
If an image cannot be found locally, then the runner will fail the build
with an error similar to:
Pulling docker image local_image:latest ...
ERROR: Build failed: Error: image local_image:latest not found
- 1
- 2
When to use the never pull policy
The never pull policy should be used if you want or need to have a full
control on which images are used by the runner’s users. It is a good choice
for private runners that are dedicated to a project where only specific images
can be used (not publicly available on any registries).
When not to use the never pull policy
The never pull policy will not work properly with most of auto-scaled
Docker executor use cases. Because of how auto-scaling works, the never
pull policy may be usable only when using a pre-defined cloud instance
images for chosen cloud provider. The image needs to contain installed
Docker Engine and local copy of used images.
Using the if-not-present pull policy
When the if-not-present pull policy is used, the runner will first check
if the image is present locally. If it is, then the local version of
image will be used. Otherwise, the runner will try to pull the image.
When to use the if-not-present pull policy
The if-not-present pull policy is a good choice if you want to use images pulled from
remote registries, but you want to reduce time spent on analyzing image
layers difference when using heavy and rarely updated images.
In that case, you will need once in a while to manually remove the image
from the local Docker Engine store to force the update of the image.
It is also the good choice if you need to use images that are built
and available only locally, but on the other hand, also need to allow to
pull images from remote registries.
When not to use the if-not-present pull policy
The if-not-present pull policy should not be used if your builds use images that
are updated frequently and need to be used in most recent versions.
In such a situation, the network load reduction created by this policy may
be less worthy than the necessity of the very frequent deletion of local
copies of images.
This pull policy should also not be used if your runner can be used by
different users which should not have access to private images used
by each other. Especially do not use this pull policy for shared runners.
To understand why the if-not-present pull policy creates security issues
when used with private images, read the
security considerations documentation.
Using the always pull policy
The always pull policy will ensure that the image is always pulled.
When always is used, the runner will try to pull the image even if a local
copy is available. The caching semantics
of the underlying image provider make this policy efficient.
The pull attempt is fast because all image layers are cached.
If the image is not found, then the build will fail with an error similar to:
Pulling docker image registry.tld/my/image:latest ...
ERROR: Build failed: Error: image registry.tld/my/image:latest not found
- 1
- 2
When using the always pull policy in GitLab Runner versions older than v1.8, it could
fall back to the local copy of an image and print a warning:
WARNING: Cannot pull the latest version of image registry.tld/my/image:latest : Error: image registry.tld/my/image:latest not found
WARNING: Locally found image will be used instead.
- 1
- 2
- 3
This was changed in GitLab Runner v1.8.
When to use the always pull policy
The always pull policy should be used if your runner is publicly available
and configured as a shared runner in your GitLab instance. It is the
only pull policy that can be considered as secure when the runner will
be used with private images.
This is also a good choice if you want to force users to always use
the newest images.
Also, this will be the best solution for an auto-scaled
configuration of the runner.
When not to use the always pull policy
The always pull policy will definitely not work if you need to use locally
stored images. In this case, the runner will skip the local copy of the image
and try to pull it from the remote registry. If the image was built locally
and doesn’t exist in any public registry (and especially in the default
Docker registry), the build will fail with:
- 1
- 2
Using multiple pull policies
Introduced in GitLab Runner 13.8.
The pull_policy parameter allows you to specify a list of pull policies.
The policies in the list will be attempted in order from left to right until a pull attempt
is successful, or the list is exhausted.
This functionality can be useful when the Docker registry is not available
and you need to increase job resiliency.
If you use the always policy and the registry is not available, the job fails even if the desired image is cached locally.
To overcome that behavior, you can add additional fallback pull policies
that execute in case of failure.
By adding a second pull policy value of if-not-present, the runner finds any locally-cached Docker image layers:
[runners.docker]
pull_policy = ["always", "if-not-present"]
- 1
- 2
Any failure to fetch the Docker image causes the runner to attempt the following pull policy.
Examples include an HTTP 403 Forbidden or an HTTP 500 Internal Server Error response from the repository.
Note that the security implications mentioned in the When not to use this pull policy? sub-section of the
Using the if-not-present pull policy section still apply,
so you should be aware of the security implications and read the
Using Docker executor with image alpine:latest ...
Pulling docker image alpine:latest ...
WARNING: Failed to pull image with policy "always": Error response from daemon: received unexpected HTTP status: 502 Bad Gateway (docker.go:143:0s)
Attempt #2: Trying "if-not-present" pull policy
Using locally found image version due to "if-not-present" pull policy
- 1
- 2
- 3
- 4
- 5
Docker vs Docker-SSH (and Docker+Machine vs Docker-SSH+Machine)
WARNING:
Starting with GitLab Runner 10.0, both Docker-SSH and Docker-SSH+machine executors
are deprecated and will be removed in one of the upcoming releases.
We provided a support for a special type of Docker executor, namely Docker-SSH
(and the autoscaled version: Docker-SSH+Machine). Docker-SSH uses the same logic
as the Docker executor, but instead of executing the script directly, it uses an
SSH client to connect to the build container.
Docker-SSH then connects to the SSH server that is running inside the container
using its internal IP.
This executor is no longer maintained and will be removed in the near future.
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/118223374
