docker配置nginx的https 最简单教程, 编译成镜像
拿我格子衫来 发表于 2022/03/17 22:33:36 2022/03/17
【摘要】 nginx的镜像中 几个重要的配置文件夹 etc/nginx/conf.d/*.conf; /usr/share/nginx   /etc/nginx/conf.d/default.conf; server { listen 80; listen [::]:80; server_nam...
/usr/share/nginx
  1. server {
  2. listen 80;
  3. listen [::]:80;
  4. server_name localhost;
  5. #charset koi8-r;
  6. #access_log /var/log/nginx/host.access.log main;
  7. location / {
  8. root /usr/share/nginx/html;
  9. index index.html index.htm;
  10. }
  11. #error_page 404 /404.html;
  12. # redirect server error pages to the static page /50x.html
  13. #
  14. error_page 500 502 503 504 /50x.html;
  15. location = /50x.html {
  16. root /usr/share/nginx/html;
  17. }
  18. # proxy the PHP scripts to Apache listening on 127.0.0.1:80
  19. #
  20. #location ~ \.php$ {
  21. # proxy_pass http://127.0.0.1;
  22. #}
  23. # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
  24. #
  25. #location ~ \.php$ {
  26. # root html;
  27. # fastcgi_pass 127.0.0.1:9000;
  28. # fastcgi_index index.php;
  29. # fastcgi_param SCRIPT_FILENAME /scripts$fastcgi_script_name;
  30. # include fastcgi_params;
  31. #}
  32. # deny access to .htaccess files, if Apache's document root
  33. # concurs with nginx's one
  34. #
  35. #location ~ /\.ht {
  36. # deny all;
  37. #}
  38. }
/etc/nginx/nginx.conf
  1. user nginx;
  2. worker_processes 1;
  3. error_log /var/log/nginx/error.log warn;
  4. pid /var/run/nginx.pid;
  5. events {
  6. worker_connections 1024;
  7. }
  8. http {
  9. include /etc/nginx/mime.types;
  10. default_type application/octet-stream;
  11. log_format main '$remote_addr - $remote_user [$time_local] "$request" '
  12. '$status $body_bytes_sent "$http_referer" '
  13. '"$http_user_agent" "$http_x_forwarded_for"';
  14. access_log /var/log/nginx/access.log main;
  15. sendfile on;
  16. #tcp_nopush on;
  17. keepalive_timeout 65;
  18. #gzip on;
  19. include /etc/nginx/conf.d/*.conf;
  20. }
分析nginx.conf 得知 在配置文件里 引入了/etc/nginx/conf.d 下的所有以.conf为结尾的配置文件
我们可以新建一个mynginx.conf 文件 编写https的配置
需要将https的证书存放在 /mywebapp/ssl目录下
  1. server {
  2. listen 443 ssl;
  3. server_name localhost;
  4. ssl_certificate /mywebapp/ssl/server.crt;
  5. ssl_certificate_key /mywebapp/ssl/server.key;
  6. ssl_session_cache shared:SSL:1m;
  7. ssl_session_timeout 5m;
  8. ssl_ciphers HIGH:!aNULL:!MD5;
  9. ssl_prefer_server_ciphers on;
  10. location / {
  11. root /mywebapp/www;
  12. index index.html index.htm;
  13. }
  14. }
使用命令  即可启动镜像, 访问https://IP 即可
docker run -d -p 443:443 doc1
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/106759548
