在docker中安装的gitlan-runner 注册Runner时失败 ubuntu
拿我格子衫来 发表于 2022/03/18 00:58:46 2022/03/18
【摘要】 ERROR: Registering runner... failed                 runner=R5udHcCx status=couldn't execute POST against http://223/api/v4/runner...
ERROR: Registering runner... failed                 runner=R5udHcCx status=couldn't execute POST against http://223/api/v4/runners: Post http://1 /api/v4/runners: dial tcp 1 3:80: connect: no route to host
PANIC: Failed to register this runner. Perhaps you are having network problems
检查防火墙, 检查脚本, 如果是https 检查证书
ping gitlab地址
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/107686444
