gitlab runner -- The Shell executor
The Shell executor
The Shell executor is a simple executor that you use to execute builds
locally on the machine where GitLab Runner is installed. It supports all systems on
which the Runner can be installed. That means that it’s possible to use scripts
generated for Bash, PowerShell Core, Windows PowerShell, and Windows Batch (deprecated).
NOTE:
Always use the latest version of Git available. Additionally, GitLab Runner will use
the git lfs command if Git LFS is installed on the machine,
so ensure Git LFS is up-to-date when GitLab Runner will run using the shell executor.
Overview
The scripts can be run as unprivileged user if the --user is added to the
gitlab-runner run command. This feature is only supported by Bash.
The source project is checked out to:
<working-directory>/builds/<short-token>/<concurrent-id>/<namespace>/<project-name>.
The caches for project are stored in
<working-directory>/cache/<namespace>/<project-name>.
Where:
<working-directory>is the value of--working-directoryas passed to the
gitlab-runner runcommand or the current directory where the Runner is
running<short-token>is a shortened version of the Runner’s token (first 8 letters)<concurrent-id>is a unique number, identifying the local job ID on the
particular Runner in context of the project<namespace>is the namespace where the project is stored on GitLab<project-name>is the name of the project as it is stored on GitLab
To overwrite the <working-directory>/builds and <working-directory/cache
specify the builds_dir and cache_dir options under the [[runners]] section
in config.toml.
Running as unprivileged user
If GitLab Runner is installed on Linux from the official .deb or .rpm
packages, the installer will try to use the gitlab_ci_multi_runner
user if found. If it is not found, it will create a gitlab-runner user and use
this instead.
All shell builds will be then executed as either the gitlab-runner or
gitlab_ci_multi_runner user.
In some testing scenarios, your builds may need to access some privileged
resources, like Docker Engine or VirtualBox. In that case you need to add the
gitlab-runner user to the respective group:
usermod -aG docker gitlab-runner
usermod -aG vboxusers gitlab-runner
- 1
- 2
Selecting your shell
GitLab Runner supports certain shells. To select a shell, specify it in your config.toml file. For example:
[[runners]]
name = "shell executor runner"
executor = "shell"
shell = "powershell"
- 1
- 2
- 3
- 4
- 5
- 6
Security
Generally it’s unsafe to run tests with shell executors. The jobs are run with
the user’s permissions (gitlab-runner) and can “steal” code from other
projects that are run on this server. Use it only for running builds on a
server you trust and own.
Terminating and killing processes
The shell executor starts the script for each job in a new process. On
UNIX systems, it sets the main process as a process
group.
GitLab Runner terminates processes when:
- A job times out.
- A job is canceled.
GitLab 13.0 and earlier
On UNIX systems gitlab-runner sends a SIGKILL to the process to
terminate it, because the child processes belong to the same process
group the signal is also sent to them. Windows sends a taskkill /F /T.
GitLab 13.1 and later
On UNIX system gitlab-runner sends SIGTERM to the process and its
child processes, and after 10 minutes sends SIGKILL. This allows for
graceful termination for the process. Windows don’t have a SIGTERM
equivalent, so the kill process is sent twice. The second is sent after
10 minutes.
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/118223336
