使用Google JS api 创建 文档
拿我格子衫来 发表于 2022/03/18 00:47:21 2022/03/18
【摘要】 需要配置 ApiKey 与YOUR_CLIENT_ID <script src="https://apis.google.com/js/api.js"></script><script> /** * Sample JavaScript code for docs.documents....
  1. <script src="https://apis.google.com/js/api.js"></script>
  2. <script>
  3. /**
  4. * Sample JavaScript code for docs.documents.create
  5. * See instructions for running APIs Explorer code samples locally:
  6. * https://developers.google.com/explorer-help/guides/code_samples#javascript
  7. */
  8. function authenticate() {
  9. return gapi.auth2.getAuthInstance()
  10. .signIn({scope: "https://www.googleapis.com/auth/documents https://www.googleapis.com/auth/drive https://www.googleapis.com/auth/drive.file"})
  11. .then(function() { console.log("Sign-in successful"); },
  12. function(err) { console.error("Error signing in", err); });
  13. }
  14. function loadClient() {
  15. gapi.client.setApiKey("YOUR_API_KEY");
  16. return gapi.client.load("https://content.googleapis.com/discovery/v1/apis/docs/v1/rest")
  17. .then(function() { console.log("GAPI client loaded for API"); },
  18. function(err) { console.error("Error loading GAPI client for API", err); });
  19. }
  20. // Make sure the client is loaded and sign-in is complete before calling this method.
  21. function execute() {
  22. return gapi.client.docs.documents.create({
  23. "resource": {}
  24. })
  25. .then(function(response) {
  26. // Handle the results here (response.result has the parsed body).
  27. console.log("Response", response);
  28. },
  29. function(err) { console.error("Execute error", err); });
  30. }
  31. gapi.load("client:auth2", function() {
  32. gapi.auth2.init({client_id: "YOUR_CLIENT_ID"});
  33. });
  34. </script>
  35. <button onclick="authenticate().then(loadClient)">authorize and load</button>
  36. <button onclick="execute()">execute</button>
  2. <script>
  3. /**
  4. * Sample JavaScript code for docs.documents.batchUpdate
  7. */
  13. }
  19. }
  22. return gapi.client.docs.documents.batchUpdate({
  23. "resource": {}
  24. })
  28. },
  30. }
  33. });
  34. </script>
使用 batchUpdate 更新文档
传入 resource  一个json对象 参数如下
https://developers.google.com/docs/api/reference/rest/v1/documents/request#Request
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/103130030
