docker构建前端项目的镜像 多种示例 写法
拿我格子衫来 发表于 2022/03/17 22:56:06 2022/03/17
【摘要】  本地编译后构建 FROM nginx:latest COPY dist /usr/share/nginx/html   示例一 FROM node:latest as builderWORKDIR /appCOPY package.json .RUN npm install --registry=http...
 本地编译后构建
  1. FROM nginx:latest
  2. COPY dist /usr/share/nginx/html
示例一
  1. FROM node:latest as builder
  2. WORKDIR /app
  3. COPY package.json .
  4. RUN npm install --registry=http://registry.npm.taobao.org
  5. COPY . .
  6. RUN npm run build
  7. FROM nginx:latest
  8. COPY nginx.conf /etc/nginx
  9. COPY --from=builder /app/build /usr/share/nginx/html
示例二
  1. FROM node:10-alpine
  2. ENV PROJECT_ENV production
  3. ENV NODE_ENV production
  4. # http-server 不变动也可以利用缓存
  5. RUN npm install -g http-server
  6. WORKDIR /code
  7. ADD package.json /code
  8. RUN npm install --production
  9. ADD . /code
  10. RUN npm run build
  11. EXPOSE 80
  12. CMD http-server ./public -p 80
示例三
  1. FROM node:10-alpine as builder
  5. WORKDIR /code
  6. ADD package.json /code
  7. RUN npm install --production
  8. ADD . /code
  9. # npm run uploadOss 是把静态资源上传至 oss 上的脚本文件
  10. RUN npm run build && npm run uploadOss
  11. # 选择更小体积的基础镜像
  12. FROM nginx:10-alpine
  13. COPY --from=builder code/public/index.html code/public/favicon.ico /usr/share/nginx/html/
  14. COPY --from=builder code/public/static /usr/share/nginx/html/static
示例四
  1. # node镜像仅仅是用来打包文件
  2. FROM node:alpine as builder
  3. ENV PROJECT_ENV production
  4. ENV NODE_ENV production
  5. COPY package*.json /app/
  6. WORKDIR /app
  7. RUN npm install --registry=https://registry.npm.taobao.org
  8. COPY . /app
  9. RUN npm run build
  10. # 选择更小体积的基础镜像
  11. FROM nginx:alpine
  12. COPY nginx.conf /etc/nginx/conf.d/default.conf
  13. COPY --from=builder /app/build /app/build
文章来源: fizzz.blog.csdn.net,作者:拿我格子衫来,版权归原作者所有,如需转载,请联系作者。
原文链接:fizzz.blog.csdn.net/article/details/106768149
