Urllib库基本使用、详解(爬虫,urlopen,request,代理ip的使用,cookie解析,异常处理,URL深入解析)
yk 坤帝 发表于 2022/03/14 23:17:03 2022/03/14
【摘要】 公众号:yk 坤帝 后台回复 Urllib库基本使用 获取全部源代码 1.什么是Urllib? 2.相⽐Python2变化 3.urlopen模块 4.响应与响应类型 4.1 状态码、...
公众号:yk 坤帝
1.什么是Urllib?
2.相⽐Python2变化
3.urlopen模块
4.响应与响应类型
4.1 状态码、响应头
4.2 request 模块
5.Handler与代理
6.cookie解析
7.异常处理
8.URL深入解析
8.1 urlparse模块
8.2 urlunparse模块
8.3 urljoin模块
8.4 urlencode模块
1.什么是Urllib?
Python内置的HTTP请求库
urllib.request 请求模块
urllib.error 异常处理模块
urllib.parse url解析模块
urllib.robotparser robots.txt解析模块
2.相⽐Python2变化
Python2
import urllib2
response = urllib2.urlopen('http://www.baidu.com')
Python3
import urllib.request
response = urllib.request.urlopen('http://www.baidu.com')
3.urlopen模块
urllib.request.urlopen(url, data=None, [timeout, ]*, cafile=None, capath=None, cadefault=False, context=None)
print(response.read().decode('utf-8'))
公众号:yk 坤帝
import urllib.parse
data = bytes(urllib.parse.urlencode({'word': 'hello'}), encoding='utf8')
response = urllib.request.urlopen('http://httpbin.org/post', data=data)
print(response.read())
response = urllib.request.urlopen('http://httpbin.org/get', timeout=1)
import socket
import urllib.error
try:
    response = urllib.request.urlopen('http://httpbin.org/get', timeout=0.1)
except urllib.error.URLError as e:
    if isinstance(e.reason, socket.timeout):
        print('TIME OUT')
4.响应与响应类型
response = urllib.request.urlopen('https://www.python.org')
print(type(response))
4.1 状态码、响应头
公众号:yk 坤帝
print(response.status)
print(response.getheaders())
print(response.getheader('Server'))
4.2 request 模块
request = urllib.request.Request('https://python.org')
response = urllib.request.urlopen(request)
from urllib import request, parse
url = 'http://httpbin.org/post'
headers = {
    'User-Agent': 'Mozilla/4.0 (compatible; MSIE 5.5; Windows NT)',
    'Host': 'httpbin.org'
dict = {
    'name': 'Germey'
data = bytes(parse.urlencode(dict), encoding='utf8')
req = request.Request(url=url, data=data, headers=headers, method='POST')
response = request.urlopen(req)
公众号:yk 坤帝
dict = {
    'name': 'Germey'
req = request.Request(url=url, data=data, method='POST')
req.add_header('User-Agent', 'Mozilla/4.0 (compatible; MSIE 5.5; Windows NT)')
5.Handler与代理ip的使用
proxy_handler = urllib.request.ProxyHandler({
    'http': 'http://127.0.0.1:9743',
    'https': 'https://127.0.0.1:9743'
opener = urllib.request.build_opener(proxy_handler)
response = opener.open('http://httpbin.org/get')
6.cookie解析
import http.cookiejar, urllib.request
cookie = http.cookiejar.CookieJar()
handler = urllib.request.HTTPCookieProcessor(cookie)
opener = urllib.request.build_opener(handler)
response = opener.open('http://www.baidu.com')
for item in cookie:
    print(item.name+"="+item.value)
filename = "cookie.txt"
cookie = http.cookiejar.MozillaCookieJar(filename)
cookie.save(ignore_discard=True, ignore_expires=True)
cookie = http.cookiejar.LWPCookieJar()
cookie.load('cookie.txt', ignore_discard=True, ignore_expires=True)
7.异常处理
from urllib import request, error
try:
    response = request.urlopen('http://cuiqingcai.com/index.htm')
except error.URLError as e:
    print(e.reason)
try:
except error.HTTPError as e:
    print(e.reason, e.code, e.headers, sep='\n')
    print(e.reason)
else:
    print('Request Successfully')
import socket
import urllib.error
try:
    response = urllib.request.urlopen('https://www.baidu.com', timeout=0.01)
    print(type(e.reason))
        print('TIME OUT')
8.URL深入解析
8.1 urlparse模块
urllib.parse.urlparse(urlstring, scheme=’’, allow_fragments=True)
from urllib.parse import urlparse
result = urlparse('http://www.baidu.com/index.html;user?id=5#comment')
print(type(result), result)
result = urlparse('www.baidu.com/index.html;user?id=5#comment', scheme='https')
print(result)
result = urlparse('http://www.baidu.com/index.html;user?id=5#comment', allow_fragments=False)
print(result)
result = urlparse('http://www.baidu.com/index.html#comment', allow_fragments=False)
print(result)
8.2 urlunparse模块
from urllib.parse import urlunparse
data = ['http', 'www.baidu.com', 'index.html', 'user', 'a=6', 'comment']
print(urlunparse(data))
8.3 urljoin模块
from urllib.parse import urljoin
print(urljoin('http://www.baidu.com', 'FAQ.html'))
print(urljoin('http://www.baidu.com', 'https://cuiqingcai.com/FAQ.html'))
print(urljoin('http://www.baidu.com/about.html', 'https://cuiqingcai.com/FAQ.html'))
print(urljoin('http://www.baidu.com/about.html', 'https://cuiqingcai.com/FAQ.html?question=2'))
print(urljoin('http://www.baidu.com?wd=abc', 'https://cuiqingcai.com/index.php'))
print(urljoin('http://www.baidu.com', '?category=2#comment'))
print(urljoin('www.baidu.com', '?category=2#comment'))
print(urljoin('www.baidu.com#comment', '?category=2'))
8.4 urlencode模块
from urllib.parse import urlencode
params = {
    'name': 'germey',
    'age': 22
base_url = 'http://www.baidu.com?'
url = base_url + urlencode(params)
print(url)
公众号:yk 坤帝
文章来源: blog.csdn.net,作者:yk 坤帝,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_45803923/article/details/123486903
