基于ModelArts实现人脸自动匹配口红色号的gif动图
雨中听雨 发表于 2022/03/11 17:46:48 2022/03/11
【摘要】 基于ModelArts实现人脸自动匹配口红色号的gif动图注意:本案例必须使用GPU运行,请查看《ModelArts JupyterLab 硬件规格使用指南》了解切换硬件规格的方法《ModelArts JupyterLab 硬件规格使用指南》https://developer.huaweicloud.cn/develop/aigallery/article/detail?id=638c55...
https://developer.huaweicloud.cn/develop/aigallery/article/detail?id=638c55c5-816d-421c-9b5f-90c804b1fa6b
开发案例介绍文档
https://developer.huaweicloud.cn/develop/aigallery/activity/detail?id=850dd5ac-2472-457b-999c-ba1270d04da9&ticket=ST-16209475-HANpcsCeSclOPRdOuaHNsL0P-sso
1.下载代码和模型文件
import os
import moxing as mox
if not os.path.exists('lipstick_lab'):
    mox.file.copy_parallel('obs://liufan-lab/lipstick', './lipstick_lab')
cd lipstick_lab
2.安装所需模块
!pip install --upgrade pip
!pip install ipywidgets
!pip install opencv-python==3.4.0.12
!pip install dlib==19.23.0
!pip install matplotlib==3.2.1
3.加载相关模块及模型
import cv2
import numpy as np
import time
import dlib
from PIL import Image
from ipywidgets import widgets
from ipywidgets import interact
from IPython.display import HTML, display
detector = dlib.get_frontal_face_detector()
predictor = dlib.shape_predictor("shape_predictor_68_face_landmarks.dat")
def createBox(img,points,scale=5,masked=False,cropped = True):
    if masked:
        mask = np.zeros_like(img)
        mask = cv2.fillPoly(mask, [points], (255, 255, 255))
        img = cv2.bitwise_and(img, mask)
        # cv2.imshow('Mask', img)
    if cropped:
        bbox = cv2.boundingRect(points)
        x, y, w, h = bbox
        imgCrop = img[y:y+h, x:x+w]
        imgCrop = cv2.resize(imgCrop, (0, 0), None, scale, scale)
        return imgCrop
    else:
        return mask
加载图片生成嘴唇的检测区域
4.加载图片生成嘴唇的检测区域 上传需要嘴唇上色的照片到lipstick_lab文件夹下并修改下面TODO代码填入照片文件名
img = cv2.imread('example2.png') # TODO 读入图片并进行人脸关键点检测
img = cv2.resize(img, (0, 0), None, 0.5, 0.5)
imgOriginal = img.copy()
imgGray = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
faces = detector(imgGray)
for face in faces:
    x1, y1 = face.left(), face.top()
    x2, y2 = face.right(), face.bottom()
    # imgOriginal = cv2.rectangle(img, (x1,y1), (x2,y2), (0, 255, 0), 2 )
    landmarks = predictor(imgGray, face)
    myPoints =[]
    for n in range(68):
        x = landmarks.part(n).x
        y = landmarks.part(n).y
        myPoints.append([x, y])
        # cv2.circle(imgOriginal, (x, y), 5, (50, 50, 255), cv2.FILLED)
        # cv2.putText(imgOriginal, str(n), (x, y-10), cv2.FONT_HERSHEY_COMPLEX_SMALL,0.9, (0, 0, 255), 1)
    myPoints = np.array(myPoints)
    # imgLeftEye = createBox(img, myPoints[36:42], 8)
    # cv2.imshow('LeftEye', imgLeftEye)
    # 2 嘴唇区域mask提取
    imgLips = createBox(img, myPoints[48:61], 8, masked=True, cropped=False)
    imgColorLips = np.zeros_like(imgLips)
5.调节RGB来生成图片
运行程序前需创建Snowflakes文件夹
!注意创建的Snowflakes文件夹必须和所运行代码的ipynb在同一个目录下
class Battery():
    def __init__(self,r,g,b,typeface,number):
        self.r = r
        self.g = g
        self.b = b
        self.typeface = typeface
        self.number = number
    def lucky(self):
        img_show_imgOriginal = cv2.resize(imgOriginal, None, fx=1, fy=1)  # 缩放为原图的0.3倍,方便展示
        img_original = Image.fromarray(img_show_imgOriginal[:, :, [2, 1, 0]])
        #display(img_original)
        imgColorLips[:] = self.b, self.g, self.r
        imgColorLips = cv2.bitwise_and(imgLips, imgColorLips)
        imgColorLips = cv2.GaussianBlur(imgColorLips, (7, 7), 10)
        #color_image
        imgColorLips = cv2.addWeighted(imgOriginal, 1, imgColorLips, 0.4, 0) # 调整口红的权重占比
        img_show_imgColorLips = cv2.resize(imgColorLips, None, fx=1, fy=1)  # 缩放为原图的0.3倍,方便展示
        img_colorlips = Image.fromarray(img_show_imgColorLips[:, :, [2, 1, 0]])
        plt.figure(figsize=(7,7))
        plt.imshow(img_colorlips)
        plt.rcParams['font.sans-serif']=['SimHei']       #中文字体识别
        plt.rcParams['axes.unicode_minus']=False
        plt.xlabel(self.typeface)
        plt.savefig('Snowflakes/'+str(self.number)+'.png')
        plt.show()
colour = {'枫叶砖红色':[178,48,41],'正红色':[194,3,13],'牛血红':[106,5,0],'番茄橘':[160,33,18],'小羊皮暖柿红':[239,93,71],
          '正橘色':[191,27,28],'珊瑚粉':[242,122,122],'玫红色':[208,10,57],'梅子色':[106,18,45],'覆盆子色':[132,40,82],'肉桂色':[229,140,122],
          '网红奶茶色':[255,190,181],'豆沙色':[183,128,115]}    #口红的颜色
number = 0
for i in colour:
    r = colour[i][0]
    g = colour[i][1]
    b = colour[i][2]
    typeface = i
    number+=1
    good = Battery(r,g,b,typeface,number)   #实例化模块
    good.lucky()
生成Git动图
import imageio
import os
def generate_gif(image_paths, gif_path, duration=0.35):  #duration=0.35为git动图的转换时间
    frames = []
    for image_path in image_paths:
        frames.append(imageio.imread(image_path))
    imageio.mimsave(gif_path, frames, 'GIF', duration=duration)
def main():
    image_folder = "Snowflakes"
    gif_path = "Snowflakes.gif"
    image_paths = []
    files = os.listdir(image_folder)   #打开文件夹
    for file in files:         #循环文件内容
        image_path = os.path.join(image_folder, file)
        image_paths.append(image_path)
    duration = 2
    generate_gif(image_paths, gif_path, duration)
if __name__ == "__main__":
    main()
git动图
产生的git动图会在创建的Snowflakes文件夹里
