dlopen failed: library “libopencv_java4.so“ not found 解决
风吹稻花香 发表于 2022/03/06 22:35:15 2022/03/06
【摘要】 dlopen failed: library "libopencv_java4.so" not found Android studio编译yolov5时报错, 最后解决方法: app所在目录的build.gradle修改: 指向opencv 的库arm64-v8a所在的父目录,报错就解决了。 extern...
最后解决方法:
  1. externalNativeBuild {
  2. cmake {
  3. version "3.10.2"
  4. path file('src/main/jni/CMakeLists.txt')
  5. }
  6. }
  7. sourceSets {
  8. main {
  9. jniLibs.srcDirs = ['src/main/jni/opencv'] // libs
  10. }
  11. }
build.gradle完整代码:
  1. apply plugin: 'com.android.application'
  2. android {
  3. compileSdkVersion 29
  4. buildToolsVersion "29.0.2"
  5. defaultConfig {
  6. applicationId "com.tencent.yolov5ncnn"
  7. archivesBaseName = "$applicationId"
  8. externalNativeBuild {
  9. cmake {
  10. cppFlags ""
  11. //
文章来源: blog.csdn.net,作者:AI视觉网奇,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jacke121/article/details/123302840
