305_python_模块2_os_md5
alexsully 发表于 2022/03/02 00:18:49 2022/03/02
【摘要】 Python内置模块2
md5 模块
import hashlib
data_str = "123456"
obj = hashlib.md5()
obj.update(data_str.encode('utf-8'))
result = obj.hexdigest()
print(result) #e10adc3949ba59abbe56e057f20f883e
DATA_DICT = {}
def md5(data_string):
    salt = "alexsuly".encode("utf-8")   #加盐防止被撞库
    obj = hashlib.md5(salt)
    obj.update(data_string.encode('utf-8'))
    return obj.hexdigest()
def register():
    user = input("用户名:")
    pwd = input("密码:")
    encrypt_pwd = md5(pwd)
    DATA_DICT[user] = encrypt_pwd
def login():
    pwd = input("密码:")
    db_pwd = DATA_DICT.get(user)
    if encrypt_pwd == db_pwd:
        print("登录成功")
    else:
        print("登录失败")
if __name__ == '__main__':
    register()
os 模块
import os
# 1. 获取当前脚本绝对路径
abs_path = os.path.abspath(__file__)
print(abs_path)  #F:\codes\PythonCodes\alexp1\models\ostest.py
# 2. 获取当前文件的上级目录
base_path = os.path.dirname( os.path.dirname(abs_path))
print(base_path)  #F:\codes\PythonCodes\alexp1
# 3. 路径拼接 join 文件更名 rename
demo_path = r'F:\codes\PythonCodes\alexp1\demo'
os.rename(os.path.join(demo_path,'1.txt'), os.path.join(demo_path, '11111.txt'))  # 只能更名文件
# 4. 判断路径是否存在
exists = os.path.exists(abs_path)
print(exists)
# 5. 创建文件夹
os.makedirs("路径")
path = os.path.join(base_path, 'xx', 'oo', 'uuuu')   #目录/路径
if not os.path.exists(path):
    os.makedirs(path)
# 6. 是否是文件夹 / 文件
os.path.isdir('file_path')
os.path.isfile('folder_path')
# 7. 删除文件或文件夹
# os.remove("hauban")
# 遍历  os.listdir(),   os.walk()
# 只罗列一级
target_path = r"F:\codes\PythonCodes\alexp1\demo"
# for item in os.listdir(target_path):
#     print(item)
1.txt
2.log
demo_1
# 遍历下面所有目录 且逐层递进, 固定返回一个元祖 包括三个item 该目录,子目录, 该目录下的文件列表
# ('F:\\codes\\PythonCodes\\alexp1\\demo', ['demo_1'], ['1.txt', '2.log']) <class 'tuple'>
for item in os.walk(target_path):
    # print(item, type(item)) #('F:\\codes\\PythonCodes\\alexp1\\demo', ['demo_1'], ['1.txt', '2.log']) <class 'tuple'>
    base_path, folder_path, file_list = item
    for i in file_list:
        if i.endswith('log'):
            abs_path = os.path.join(base_path,i)
            # print(abs_path)   #//F:\codes\PythonCodes\alexp1\demo\2.log
