Springboot+Element ui Vue图片上传回显
【摘要】 最近个人自己做前后端分离项目、遇到了图片上传、简单记录一下。前端vue element UI部分需要提交的表单数据如下: <el-col :span="24"> <el-form-item class="upload" v-if="type!='info' && !ro.touxiang" label="头像文件" prop="touxiang"> <f...
<el-col :span="24">
<file-upload
tip="点击上传头像文件"
action="file/upload"
:limit="3"
:multiple="true"
:fileUrls="ruleForm.touxiang?ruleForm.touxiang:''"
@change="touxiangUploadChange"
></file-upload>
</el-form-item>
<div v-else>
<el-form-item v-if="ruleForm.touxiang" label="头像" prop="touxiang">
<img style="margin-right:20px;" v-bind:key="index" v-for="(item,index) in ruleForm.touxiang.split(',')" :src="item" width="100" height="100">
</el-form-item>
</div>
</el-col>
复制代码
后端controller接口:
@Async
@RequestMapping("/upload")
public R upload(@RequestParam("file") MultipartFile file,String type) throws Exception {
if (file.isEmpty()) {
throw new EIException("上传文件不能为空");
String fileExt = file.getOriginalFilename().substring(file.getOriginalFilename().lastIndexOf(".")+1);
File upload = new File("D:/work/");//这里只是参考演示、路径建议写在配置文件里面
if(!upload.exists()) {
upload.mkdirs();
String fileName = new Date().getTime()+"."+fileExt;
File dest = new File(upload+"/"+fileName);
file.transferTo(dest);
if(StringUtils.isNotBlank(type) && type.equals("1")) {
ConfigEntity configEntity = configService.selectOne(new EntityWrapper<ConfigEntity>().eq("name", "faceFile"));
if(configEntity==null) {
configEntity = new ConfigEntity();
configEntity.setName("faceFile");
configEntity.setValue(fileName);
configService.insertOrUpdate(configEntity);
return R.ok().put("file", fileName);
复制代码
Spring boot 配置拦截器Interceptor处理放行等:
@Configuration
public class InterceptorConfig extends WebMvcConfigurationSupport{
@Bean
public AuthorizationInterceptor getAuthorizationInterceptor() {
return new AuthorizationInterceptor();
@Override
public void addInterceptors(InterceptorRegistry registry) {
registry.addInterceptor(getAuthorizationInterceptor()).addPathPatterns("/**").excludePathPatterns("/static/**");
super.addInterceptors(registry);
* springboot 2.0配置WebMvcConfigurationSupport之后,会导致默认配置被覆盖,要访问静态资源需要重写addResourceHandlers方法
@Override
public void addResourceHandlers(ResourceHandlerRegistry registry) {
registry.addResourceHandler("/**")
.addResourceLocations("classpath:/resources/")
.addResourceLocations("classpath:/static/")
.addResourceLocations("classpath:/admin/")
.addResourceLocations("classpath:/front/")
.addResourceLocations("classpath:/public/");
registry.addResourceHandler("/upload/**").addResourceLocations("file:D:/work/");
super.addResourceHandlers(registry);
复制代码
YML配置文件加载静态资源文件:
resources: static-locations: classpath:/testStatic/,classpath:/META-INF/resources/,classpath:/resources/,classpath:/static/,classpath:/public/ 复制代码
以上就是springboot配合vue+elementui上传图片回显的方式。
打卡 文章 更新 201 / 365天
大家可以点赞、收藏、关注、评论我啦 ~!
cloudbbs@huaweicloud.com
