HTML+CSS+JS实现 彩色3D线条动画特效
Java李杨勇 发表于 2022/02/28 21:15:43 2022/02/28
【摘要】 HTML+CSS+JS实现 彩色3D线条动画特效
   效果演示:
代码目录:
主要代码实现:
HTML代码 :
<!doctype html>
<html>
<head>
    <meta charset="utf-8">
    <title>彩带特效</title>
</head>
<body>
    <script id="fs" type="x-shader/x-fragment">
        precision mediump float; uniform float time; uniform vec2 mouse; uniform vec2 resolution; // window ratio float ratio = resolution.x / resolution.y; float PI = 3.1415926; float line(vec2 p, float pct, float i) { return smoothstep(pct - sin(time / i) *
        0.06, pct, p.y) - smoothstep(pct, pct + sin(time / i) * 0.06, p.y); } vec2 rotate2d(vec2 p, float angle) { p = mat2(cos(angle), -sin(angle), sin(angle), cos(angle)) * p; return p; } void main(void) { // center center vec2 p = vec2(gl_FragCoord.xy
        * 2.0 - resolution) / min(resolution.x, resolution.y); // left bottom //vec2 p = gl_FragCoord.xy / resolution.xy; float l = length(p); vec3 c = vec3(0.0); vec3 d = vec3(l, 1.0 - p.x, 1.0 - p.y); for (float i = 1.0; i
        <=3 6.0; i++) { p=r
            otate2d(p, i * 10.0); float s=t ime / i; float y=s in(p.x + s) * 0.4 * l; float pct=l ine(p, y, i); c +=p ct; } gl_FragColor=v ec4(c * d, 1.0); } </script>
            <script id="vs" type="x-shader/x-vertex">
                attribute vec3 position; void main(void){ gl_Position = vec4(position, 1.0); }
            </script>
            <script>
                // variable for global
                let c, // canvas
                    cw, ch, // window size
                    mx, my, // mouse
                    gl, // context
                    uniLocation, // for shader
                    run, // not used
                    eCheck, // not used
                    startTime, time, tempTime; // times
                 * Make canvas
                const createCanvas = () => {
                    const b = document.getElementsByTagName('body')[0];
                    const c = document.createElement('canvas');
                    c.setAttribute('id', 'canvas');
                    c.style.position = 'fixed';
                    c.style.display = 'block';
                    c.style.zIndex = '-1';
                    c.style.top = '0';
                    c.style.left = '0';
                    c.style.width = '100%';
                    c.style.height = '100%';
                    c.style.background = 'black';
                    b.appendChild(c);
                 * Check event
                 * @params {Object} e - check event
                const checkChange = e => {
                    run = e.currentTarget.checked;
                    if (run) {
                        startTime = new Date().getTime();
                        render();
                        tempTime += time;
                 * Mouse event
                 * @params {Object} e - mouse event
                const mouseMove = e => {
                    mx = e.clientX / cw;
                    my = e.clientY / ch;
                 * Resize window
                const resizeWindow = () => {
                    cw = c.width = window.innerWidth;
                    ch = c.height = window.innerHeight;
                    init();
                 * Rendering function
                const render = () => {
                    // run?
                    if (!run) return;
                    // time
                    time = (new Date().getTime() - startTime) * 0.001;
                    // clear color
                    gl.clear(gl.COLOR_BUFFER_BIT);
                    // uniforms
                    gl.uniform1f(uniLocation[0], time);
                    gl.uniform2fv(uniLocation[1], [mx, my]);
                    gl.uniform2fv(uniLocation[2], [cw, ch]);
                    // draw
                    gl.drawElements(gl.TRIANGLES, 6, gl.UNSIGNED_SHORT, 0);
                    gl.flush();
                    // recur
                    requestAnimationFrame(render);
                 * Create shader
                 * @params {String} id - element id
                 * @return {Object} shader - shader object
                const create_shader = id => {
                    let shader;
                    // get reference tag
                    const scriptElement = document.getElementById(id);
                    // if not exsist return
                    if (!scriptElement) return;
                    // check script attribute
                    switch (scriptElement.type) {
                        // vertex shader
                        case 'x-shader/x-vertex':
                            shader = gl.createShader(gl.VERTEX_SHADER);
                            break;
                            // fragment shader
                        case 'x-shader/x-fragment':
                            shader = gl.createShader(gl.FRAGMENT_SHADER);
                            break;
                        default:
                            return;
                    // assign source to shader
                    gl.shaderSource(shader, scriptElement.text);
                    // compile shader
                    gl.compileShader(shader);
                    // check shader was compiled?
                    if (gl.getShaderParameter(shader, gl.COMPILE_STATUS)) {
                        return shader;
                        console.log(gl.getShaderInfoLog(shader));
                 * Create program object and link shader function
                 * @param {String} vs - element name
                 * @param {String} fs - element name
                 * @return {object} program - return program object
                const create_program = (vs, fs) => {
                    let program;
                    // create program object
                    program = gl.createProgram();
                    // attach shader program object
                    gl.attachShader(program, vs);
                    gl.attachShader(program, fs);
                    // link shader
                    gl.linkProgram(program);
                    // check shader link
                    if (gl.getProgramParameter(program, gl.LINK_STATUS)) {
                        // if success enable program
                        gl.useProgram(program);
                        return program;
                        return null;
                 * Create vbo function
                 * @param {Array} - Array in position
                 * @return {Object} - vertex buffer object
                const create_vbo = data => {
                    //create buffer object
                    const vbo = gl.createBuffer();
                    // bind buffer
                    gl.bindBuffer(gl.ARRAY_BUFFER, vbo);
                    // set data to buffer
                    gl.bufferData(gl.ARRAY_BUFFER, new Float32Array(data), gl.STATIC_DRAW);
                    // invalidata buffer
                    gl.bindBuffer(gl.ARRAY_BUFFER, null);
                    return vbo;
                 * Create index buffer object function
                 * @param {Array} data - Array in index
                 * @return {Object} ibo - index buffer object
                const create_ibo = data => {
                    // create buffer object
                    const ibo = gl.createBuffer();
                    // bind buffer
                    gl.bindBuffer(gl.ELEMENT_ARRAY_BUFFER, ibo);
                    gl.bufferData(gl.ELEMENT_ARRAY_BUFFER, new Int16Array(data), gl.STATIC_DRAW);
                    // invalidate buffer
                    gl.bindBuffer(gl.ELEMENT_ARRAY_BUFFER, null);
                    return ibo;
                 * Init canvas
                const init = () => {
                    time = 0.0;
                    tempTime = 0.0;
                    uniLocation = new Array();
                    // get element
                    c = document.getElementById('canvas');
                    //eCheck = document.getElementById('check');
                    // canvas size
                    // get webgl context
                    gl = c.getContext('webgl') || c.getContext('experimental-webgl');
                    // set viewport
                    gl.viewport(0, 0, cw, ch);
                    // init shader
                    const prg = create_program(create_shader('vs'), create_shader('fs'));
                    run = prg != null;
                    if (!run) {
                        eCheck.checked = false;
                    uniLocation[0] = gl.getUniformLocation(prg, 'time');
                    uniLocation[1] = gl.getUniformLocation(prg, 'mouse');
                    uniLocation[2] = gl.getUniformLocation(prg, 'resolution');
                    // init vertex
                    const position = [-1.0, 1.0, 0.0,
                        1.0, 1.0, 0.0, -1.0, -1.0, 0.0,
                        1.0, -1.0, 0.0
                    const index = [
                        0, 2, 1,
                        1, 2, 3
                    const vPosition = create_vbo(position);
                    const vIndex = create_ibo(index);
                    const vAttLocation = gl.getAttribLocation(prg, 'position');
                    gl.bindBuffer(gl.ARRAY_BUFFER, vPosition);
                    gl.enableVertexAttribArray(vAttLocation);
                    gl.vertexAttribPointer(vAttLocation, 3, gl.FLOAT, false, 0, 0);
                    gl.bindBuffer(gl.ELEMENT_ARRAY_BUFFER, vIndex);
                    // etc init
                    gl.clearColor(0.0, 0.0, 0.0, 1.0);
                    mx = 0.5;
                    my = 0.5;
                window.addEventListener('load', () => {
                    createCanvas();
                    init();
                    render();
                    // event
                    c.addEventListener('mousemove', mouseMove, false);
                    //eCheck.addEventListener('change', checkChange, false);
                    window.addEventListener('resize', resizeWindow, false);
                }, false);
            </script>
</body>
</html>
源码获取
查看博主主页或私信博主获取
精彩推荐更新中:
HTML5大作业实战100套
  打卡 文章 更新 40  /  100天
大家可以点赞、收藏、关注、评论我啦 、需要完整文件随时联系我或交流哟~!
在这里插入图片描述​
