JavaWeb课程复习资料(九)——删除功能
红目香薰 发表于 2022/02/27 14:16:21 2022/02/27
【摘要】 ​ 承接上文:JavaWeb课程复习资料(八)——添加功能1、创建【DeleteByIdServlet.jsp】​2、添加【DeleteByIdServlet.jsp】编码package com.item.servlet;import com.item.dao.UserInfoDAO;import com.item.daoimpl.UserInfoDAOImpl;import javax.s...
import javax.servlet.ServletException;
import javax.servlet.annotation.WebServlet;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import java.io.IOException;
import java.io.PrintWriter;
@WebServlet("/DeleteByIdServlet")
public class DeleteByIdServlet extends HttpServlet {
    @Override
    protected void doPost(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
        resp.setContentType("text/html;charset=utf-8");
        req.setCharacterEncoding("utf-8");
        String id=req.getParameter("id");
        UserInfoDAO db =new UserInfoDAOImpl();
        boolean isf = db.DeleteById(Integer.parseInt(id));
        PrintWriter out = resp.getWriter();
        if(isf){
            out.println("<script>alert('删除成功');window.location.href='/index.jsp';</script>");
        }else{
            out.println("<script>alert('删除失败');window.location.href='/index.jsp';</script>");
    @Override
    protected void doGet(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
        doPost(req,resp);
3、启动测试
删除完成
再删几个试试:
 没删除一个都会有提示:​
