JavaWeb课程复习资料(三)——将【resultSet】形式的数据转为List<T>的形式
红目香薰 发表于 2022/02/27 14:13:43 2022/02/27
【摘要】 ​承接上文链接:JavaWeb课程复习资料(二)——idea创建JDBC(FactoryDB)本文会将【resultSet】形式的数据转为list<T>的形式1、创建【com.item.pojo】包,并创建表对应的类【UserInfo】需要私有化的属性,set、get、所有参数的构造方法、空构造方法。package com.item.pojo;import java.util.Date;pu...
承接上文链接:
public class UserInfo {
    private int id;
    private Date createDate;
    private String userName;
    private String introduce;
    public int getId() {
        return id;
    public void setId(int id) {
        this.id = id;
    public Date getCreateDate() {
        return createDate;
    public void setCreateDate(Date createDate) {
        this.createDate = createDate;
    public String getUserName() {
        return userName;
    public void setUserName(String userName) {
        this.userName = userName;
    public String getIntroduce() {
        return introduce;
    public void setIntroduce(String introduce) {
        this.introduce = introduce;
    public UserInfo(int id, Date createDate, String userName, String introduce) {
        this.id = id;
    public UserInfo() {
2、在【com.item.demo/Action.java】中完成测试
由于实际操作中候纯粹的做【add】操作,故而使用LinkedList进行操作。
package com.item.demo;
import com.item.jdbc.FactoryDB;
import com.item.pojo.UserInfo;
import java.sql.Connection;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.util.LinkedList;
import java.util.List;
public class Action {
        Connection conn = FactoryDB.GetConnection();
        try {
            PreparedStatement pre = conn.prepareStatement("select * from userinfo");
            ResultSet res = pre.executeQuery();
            //由于只做添加操作,故而使用LinkedList
            LinkedList<UserInfo> list=new LinkedList<UserInfo>();
            while (res.next()){
                list.add(new UserInfo(res.getInt(1),res.getDate(2),
                        res.getString(3),res.getString(4)));
            for(UserInfo info:list){
               System.out.print("id:"+info.getId()+"\t");
               System.out.print("createDate:"+info.getCreateDate()+"\t");
               System.out.print("userName:"+info.getUserName()+"\t");
               System.out.println("introduce:"+info.getIntroduce()+"\t");
            FactoryDB.Close(conn,pre,res);
        } catch (SQLException e) {
            e.printStackTrace();
​完成所有操作。
