C#使用UdpClient发送和接收UDP数据示例 16进制与字符串互转
dujiahei 发表于 2022/02/24 22:55:40 2022/02/24
【摘要】 C#使用UdpClient发送和接收UDP数据示例 16进制与字符串互转 - CSDN博客  http://blog.csdn.net/xuehuic/article/details/53812647 1.服务器 [csharp]  view plain &nbsp...
1.服务器
[csharp]  view plain  copy
  1. using System;
  2. using System.Net;
  3. using System.Net.Sockets;
  4. using System.Text;
  5.
  6. namespace ConsoleApplication1
  7. {
  8.     class Program
  9.     {
  10.         static void Main(string[] args)
  11.         {
  12.             Server(10086); //监听10086端口
  13.         }
  14.
  15.         /// <summary>
  16.         /// 服务器端
  17.         /// </summary>
  18.         /// <param name="port"></param>
  19.         static void Server(int port)
  20.         {
  21.             try
  22.             {
  23.                 UdpClient udpclient = new UdpClient(port);
  24.                 while (true)
  25.                 {
  26.                     IPEndPoint ipendpoint = null;
  27.                     byte[] bytes = udpclient.Receive(ref ipendpoint); //停在这等待数据
  28.                     string data = Encoding.Default.GetString(bytes, 0, bytes.Length);
  29.
  30.                     Console.WriteLine("{0:HH:mm:ss}->接收数据(from {1}:{2}):{3}", DateTime.Now, ipendpoint.Address, ipendpoint.Port, data);
  31.                 }
  32.                 udpclient.Close();
  33.             }
  34.             catch (Exception ex)
  35.             {
  36.                 Console.WriteLine("{0:HH:mm:ss}->{1}", DateTime.Now, ex.Message);
  37.             }
  38.             Console.ReadKey();
  39.         }
  40.     }
  41. }
2.客户端
  1. using System;
  5.
  7. {
  8.     class Program
  9.     {
  11.         {
  12.             Client("127.0.0.1", 10086, "play"); //发送数据
  13.         }
  14.
  15.         /// <summary>
  16.         /// 客户端
  17.         /// </summary>
  18.         /// <param name="ip"></param>
  19.         /// <param name="port"></param>
  20.         /// <param name="message"></param>
  21.         static void Client(string ip, int port, string message)
  22.         {
  23.             try
  24.             {
  25.                 UdpClient udpclient = new UdpClient();
  26.                 IPEndPoint ipendpoint = new IPEndPoint(IPAddress.Parse(ip), port);
  27.                 byte[] data = Encoding.Default.GetBytes(message);
  28.                 udpclient.Send(data, data.Length, ipendpoint);
  29.                 udpclient.Close();
  30.
  31.                 Console.WriteLine("{0:HH:mm:ss}->发送数据(to {1}):{2}", DateTime.Now, ip, message);
  32.             }
  33.             catch (Exception ex)
  34.             {
  35.                 Console.WriteLine("{0:HH:mm:ss}->{1}", DateTime.Now, ex.Message);
  36.             }
  37.             Console.ReadKey();
  38.         }
  39.     }
  40. }
3. 字符串转16进制,然后直接发送16进制。
  1. public static byte[] HexStringToByteArray(string s)
  2.         {
  3.             if (s.Length = 0)
  4.                 throw new Exception("将16进制字符串转换成字节数组时出错,错误信息:被转换的字符串长度为0。");
  5.             s = s.Replace(" ", "");
  6.             byte[] buffer = new byte[s.Length / 2];
  7.             for (int i = 0; i < s.Length; i += 2)
  8.                 buffer[i / 2] = Convert.ToByte(s.Substring(i, 2), 16);
  9.             return buffer;
  10.         }
4.16进制转字符串,接收端用于识别显示
  1. /// <summary>
  2. /// 字节数组转换成十六进制字符串(不带空格)
  3. /// </summary>
  4. /// <param name="data">要转换的字节数组</param>
  5. /// <returns>转换后的字符串</returns>
  6. public static string ByteArrayToHexStringNoBlank(byte[] data)
  7. {
  8.     StringBuilder sb = new StringBuilder(data.Length * 3);
  9.     foreach (byte b in data)
  10.         sb.Append(Convert.ToString(b, 16).PadLeft(2, '0'));
  11.     return sb.ToString().ToUpper();
  12. }
文章来源: dujiahei.blog.csdn.net,作者:dujiahei,版权归原作者所有,如需转载,请联系作者。
原文链接:dujiahei.blog.csdn.net/article/details/78388201
