leetcode 82& 21
流星雨的梦 发表于 2022/02/24 00:58:33 2022/02/24
【摘要】 # Definition for singly-linked list. # class ListNode: # def __init__(self, x): # self.v...
# class ListNode:
#         self.val = x
#         self.next = None
class Solution:
    def deleteDuplicates(self, head: ListNode) -> ListNode:
        # 编程时,如果nex可以省略,比如总是和cur是相邻的,可以不定义出来,以免后续cur最后,nex为None,nex.next报错
        # and和or条件计算时,具有短路效应,具体表现为:and左边为False后,不再计算右边,不进入循环
        # or 左边为True后,不计算右边,直接进入循环
        dummy = ListNode(-1)
        dummy.next = head
        pre = dummy
        cur = head
        while cur:
            while cur.next and cur.val == cur.next.val:
                cur = cur.next
            if pre.next == cur:
                pre = cur
            else:
                pre.next = cur.next
            cur = cur.next
        return dummy.next
# class ListNode:
#         self.val = x
#         self.next = None
class Solution:
    def mergeTwoLists(self, l1: ListNode, l2: ListNode) -> ListNode:
        cur = dummy
        while l1 and l2:
            if l1.val < l2.val:
                cur.next = l1
                l1 = l1.next
            else:
                cur.next = l2
                l2 = l2.next
            cur = cur.next
        while l1:
            cur.next = l1
            l1 = l1.next
            cur = cur.next
        while l2:
            cur.next = l2
            l2 = l2.next
            cur = cur.next
        return dummy.next
  • 26
  • 27
  • 28
文章来源: blog.csdn.net,作者:weixin_43178406,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_43178406/article/details/88032116
