python使用xlwt、xlsxwriter生成Excel
时光不写 发表于 2022/02/22 19:32:12 2022/02/22
【摘要】 试了几种方式,发现关闭不了科学计数法,定义一个方法转换数据的格式, 如果有好的方法请留言分享,多谢!def data_processing(data): ‘’‘ 数据处理, 把大于10000000000的数据转为str类型 ’‘’ res = [] for i in data: try: if i is None: ...
  • 试了几种方式,发现关闭不了科学计数法,定义一个方法转换数据的格式, 如果有好的方法请留言分享,多谢!
        res = []
        for i in data:
            try:
                if i is None:
                    r = ''
                elif '.' in str(i):
                    r = float(i)
                else:
                    r = int(i)
            except ValueError:
                r = i
            if isinstance(r, (int, float)):
                if r > 10000000000:
                    r = str(r)
            else:
                r = str(r)
            res.append(r)
        return res
使用xlwt
  • 实现方式
    def excel_(headers, result, file_name, horizontal=True):
        f = xlwt.Workbook()
        default_easyxf = xlwt.easyxf(num_format_str='0.00')
        sheet1 = f.add_sheet('sheet1')
        # 标红加粗
        # style = "font:colour_index 10, bold False"
        # style = xlwt.easyxf(style)
        if horizontal:
            for i in range(0, len(headers)):
                if isinstance(headers[i], tuple):
                    sheet1.write(0, i, headers[i][0], xlwt.easyxf(headers[i][1]))
                    continue
                sheet1.write(0, i, headers[i])
            row_index = 0
        else:
            r = []
            for k, v in zip(headers, result):
                r.append([k, v])
            result = r
            row_index = -1
        for rows in result:
            row_index += 1
            for j in range(0, len(rows)):
                try:
                    if not rows[j]:
                        r = ''
                    elif '.' in str(rows[j]):
                        r = float(rows[j])
                    else:
                        r = int(rows[j])
                except ValueError:
                    r = rows[j]
                    # 数值格式
                    if r < 10000000000:
                        sheet1.write(row_index, j, r, default_easyxf)
                    else:
                        sheet1.write(row_index, j, str(r))
                else:
        # 保存到本地
        # f.save("/User/name/{}".format(file_name))
        excel_stream = io.BytesIO()
        # BytesIO流(在内存中读写)
        f.save(excel_stream)
        res = excel_stream.getvalue()
        excel_stream.close()
        response = HttpResponse(content_type='application/vnd.ms-excel')
        from urllib import parse
        response['Content-Disposition'] = 'attachment;filename=' + parse.quote(file_name)
        response.write(res)
        return response
    headers = ["姓名", ("手机号", "font:colour_index 10, bold False")]
    results = [["李白", "1888888888"], ["杜甫", "19999999999"]]
    file_name = "test.xlsx"
    excel_(headers, results, file_name)
使用xlsxwriter
  • 实现方式
    # excel下拉列表导出,数据校验
    def xlsx_excel(headers, results, filename):
        workbook = xlsxwriter.Workbook(excel_stream)
        worksheet = workbook.add_worksheet()
        # 数字格式
        header_format = workbook.add_format({
            'num_format': '0',
        # 文本格式
        str_format = workbook.add_format()
        str_format.set_num_format('@')
        # 下拉列表校验格式
        data_validate = {'validate': 'list', 'source': ['是', '否']}
        data_validate1 = {'validate': 'list', 'source': ['有', '无']}
        # 日期格式校验
        date_validate = {'validate': 'date',
                         'criteria': 'between',
                         'minimum': date(2018, 1, 1),
                         'maximum': date(9999, 12, 12)}
        for i in range(len(headers)):
            # 写入校验规则
                # 写入计算公式
                if "自动计算" in headers[i][0]:
                    worksheet.write(0, i, headers[i][0])
                    worksheet.write_formula(1, i, headers[i][1], header_format)
                # 使用之前定义的header_format数字格式
                elif "text" in headers[i][1]:
                    r = headers[i][1].replace('text', '')
                    worksheet.write(0, i, headers[i][0], workbook.add_format({'font_color': 'red'}))
                    # 单独设置文本格式
                    worksheet.set_column("{}:{}".format(r, r), None, str_format)
                # 使用之前定义的date_validate日期格式
                elif "date" in headers[i][1]:
                    r = headers[i][1].replace('date', '')
                    worksheet.data_validation('{}2:{}1048576'.format(r, r), date_validate)
                # 使用之前定义的data_validate下拉规则
                else:
                    worksheet.data_validation('{}2:{}1048576'.format(headers[i][1], headers[i][1]), data_validate)
            else:
                worksheet.write(0, i, headers[i], workbook.add_format({'font_color': 'red'}))
        # 整行写入数据
        for x in range(len(results)):
            worksheet.write_row("A{}".format(x + 2), results[x])
        workbook.close()
        xlsx_data = excel_stream.getvalue()
        response = HttpResponse(content_type='application/ms-excel')
        response['Content-Disposition'] = 'attachment; filename=%s.xlsx' % filename
        response.write(xlsx_data)
        return response
    headers = [("日期", 'dateA'), "姓名", ("手机号", "textC"), "数字一", "数字二",
               ("合计(自动计算)", "=D2+E2")]
    results = [["2019/1/1", "张三", "18888888888", "1000", 1000]]
    filename = "test_excel"
