单链表的建立
ReCclay 发表于 2022/02/22 00:52:03 2022/02/22
【摘要】 #include <stdio.h> #include <stdlib.h> struct node { int data; struct node *next; ...
#include <stdio.h>
#include <stdlib.h>
struct node
    int data;
    struct node *next;
typedef struct node LNode, *LinkList;
void CreateList(LinkList head);
void PrintList(LinkList head);
void ListDelete(LinkList head, int i, int *e);
void ListInsert(LinkList head, int i, int e);
int main()
    LinkList head;
    int i, e, select;
    head = (LinkList) malloc (sizeof(LNode));
    head -> next = NULL;
    while(1)
        printf("1: Create a list.\n");
        printf("2: Insert some elements in the list.\n");
        printf("3: Delete some elements.\n");
        printf("4: Print the list.\n");
        printf("0: Quit!\n");
        scanf("%d", &select);
        switch(select)
            case 1: CreateList(head); break;
            case 2: printf("Input position and name of the element.\n");
                    scanf("%d%d", &i, &e);
                    ListInsert(head, i, e);
                    break;
            case 3: printf("Input the position of the element.\n");
                    scanf("%d", &i);
                    ListDelete(head, i, &e);
            case 4: PrintList(head);
                    printf("\n");
                    break;
            case 0:
                    exit(0);
    return 0;
//void CreateList()//头插法
//    LinkList p;
//    int num;
//    while(scanf("%d", &num), num!=-1)
//        p = (LinkList)malloc(sizeof(LNode));
//        p ->data = num;
//        p ->next = head ->next;
//        head ->next = p;
void CreateList(LinkList head)//尾插法
    LinkList p, rear = head;
    int num;
        p ->data = num;
        rear ->next = p;
        rear = p;
    rear ->next = NULL;
    LinkList p = head ->next;
    while(p)
        printf("%d\n", p ->data);
        p = p ->next;
void ListInsert(LinkList head, int i, int e)//变相的头插法
    LinkList p, pre = head;
    int j = 0;
    while(pre && j<i+1)
        pre = pre ->next;
        j++;
    if(!pre || i<1)
        printf("Input i error\n");
        return;
    p ->data = e;
    p ->next = pre->next;
    pre ->next = p;
    LinkList p, pre;
    int j=0;
    while(pre && j<i-1)
        pre = pre ->next;
        j++;
    if(!pre || i<1)
        return;
    p = pre ->next;
    pre ->next = p ->next;
    *e = p->data;
    free(p);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
文章来源: recclay.blog.csdn.net,作者:ReCclay,版权归原作者所有,如需转载,请联系作者。
原文链接:recclay.blog.csdn.net/article/details/60953553
