配置PCA的一点总结12单片机
ReCclay 发表于 2022/02/22 00:04:38 2022/02/22
【摘要】 先看代码 #include "stc12.h" unsigned int Last_Capture_Data=0; unsigned int New_Capture_Data=0; unsign...
先看代码
#include "stc12.h"
unsigned int g_Period=0;
unsigned int g_Frequency=0;
unsigned char str1[12];
unsigned char str2[12];
bit Capture_over = 0;
sbit KEY_1 = P2^7;
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
void Delay50ms();
void PCA_Init (bit module);
void IntToString(unsigned char *str, unsigned int dat);
void main (void)
    PCA_Init(0);
    InitLcd1602();
    P2 = 0xF7;
    while(1)
        if(!KEY_1)
            Delay50ms();
            if(!KEY_1)
                while(!KEY_1);
                CCAPM0 = 0x11;
                CR = 1;
        if(Capture_over)
            Capture_over = 0;
//                           g_Frequency = (long)1000000 / g_Period;
            g_Frequency = (long)11059200 / (g_Period * 12);
            IntToString(str1, g_Period);
            IntToString(str2, g_Frequency);
            LcdShowStr(1, 0, "length:");
            LcdShowStr(8, 0, str1);
            LcdShowStr(1, 1, "freque:");
            LcdShowStr(8, 1, str2);
    //CIDL    -       -       -       CPS2    CPS1    CPS0    ECF
    CMOD = 0x80;
    //CF      CR      -       -       -       -       CCF1    CCF0
    CCON = 0x00;
    if (module == 0)
        CCAPM0 = 0x10;
        CCAP0L = 0x00;
        CCAP0H = 0x00;
    else
        CCAPM1 = 0x11;
        CCAP1L = 0x00;
        CCAP1H = 0x00;
    CL = 0x00;
    CH = 0x00;
    EA = 1;
    //CR = 1;
    unsigned char buf[12];
    unsigned char i = 0;
    do{
        buf[i++] = dat % 10;
        dat /= 10;
    }while(dat > 0);
    while(i-- > 0)
        *str++ = buf[i] + '0';//数组转换成ASCII反向拷贝到字符串指针
    *str = '\0';
void PCA_Int(void) interrupt 7
    if (CCF0)
        CCF0 = 0;
        if(Last_Capture_Data == 0)
              Last_Capture_Data = CCAP0H;
              Last_Capture_Data = (Last_Capture_Data << 8) + CCAP0L;
        else
            New_Capture_Data = CCAP0H;
            New_Capture_Data = (New_Capture_Data << 8) + CCAP0L;
            g_Period = New_Capture_Data - Last_Capture_Data;
            CR = 0;
            CCAPM0 = 0x10;
            CCAP0L = 0x00;
            CCAP0H = 0x00;
            CL = 0x00;
            CH = 0x00;
            Capture_over = 1;
void Delay50ms()        //@11.0592MHz
    unsigned char i, j, k;
    i = 3;
    j = 26;
    k = 223;
    do
        do
            while (--k);
        } while (--j);
    } while (--i);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
配置流程:
  1. CMOD 设置禁止溢出中断
  2. 设置CCAPMx设置开启捕获中断,以及上升沿捕获还是下降沿捕获
  3. 清零CCnPL、CCnPH以及CH、CL
这里写图片描述
其实最重要的还得看手册,介绍的真心很详细!!!
一个非常详细的电路图,分分享一下:
这里写图片描述
很明显,图的意思就是设置好上升沿捕获或者下降沿捕获后,由于CL、CH
一直在走,一旦满足条件就把CL./CH的值分别装入CCAPL以及CCAPH中,如果此时使能PCA中断的话,会触发中断进入中断。
文章来源: recclay.blog.csdn.net,作者:ReCclay,版权归原作者所有,如需转载,请联系作者。
原文链接:recclay.blog.csdn.net/article/details/75769620
