Android学习之按钮的点击、触摸、开关
ReCclay 发表于 2022/02/22 01:21:11 2022/02/22
【摘要】 别忘了,每申请一个活动都需要在AndroidManifest中注册! 点击 app/src/main/java/包名/MainActivity.java public class MainAct...
点击
  • app/src/main/java/包名/MainActivity.java
public class MainActivity extends AppCompatActivity {
    private Button button;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        button = (Button)findViewById(R.id.button11);
        button.setOnClickListener(buttonClickListener);
    private View.OnClickListener buttonClickListener = new View.OnClickListener() {
        @Override
        public void onClick(View view) {
            //button动作
触摸
需要在先添加相应的样式。
  • app/src/main/res/drawable/button_up
<shape xmlns:android="http://schemas.android.com/apk/res/android"
    android:shape="rectangle" >
    <corners
        android:radius="7dp" />
    <solid
        android:color="@android:color/holo_orange_light" />
    <stroke
        android:width="1dp"
        android:color="@android:color/holo_red_light" />
</shape>
  • app/src/main/res/drawable/button_down
    <corners
    <solid
        android:color="@android:color/holo_orange_dark" />
    <stroke
        android:width="1dp"
</shape>
布局文件中引用
  • app/src/main/res/layout/activity_main.xml
android:textColor="@android:color/black"
android:background="@drawable/button_up"
/*触摸事件*/
private View.OnTouchListener buttonJumpTouch = new View.OnTouchListener() {
   @Override
   public boolean onTouch(View v, MotionEvent event) {
       // TODO Auto-generated method stub
       if (event.getAction()==MotionEvent.ACTION_DOWN) {
           buttonJump.setBackgroundResource(R.drawable.button_down);
       if (event.getAction()==MotionEvent.ACTION_UP) {
           buttonJump.setBackgroundResource(R.drawable.button_up);
       return false;
以上的触摸还有一种更好的写法,
- app/src/main/res/drawable目录需要放置button_up、button_down
然后呢,只需要再多多放一个button_shape
<selector xmlns:android="http://schemas.android.com/apk/res/android">
    <item android:state_pressed="true" android:drawable="@drawable/button_down"/>
    <item android:state_pressed="false" android:drawable="@drawable/button_up"/>
</selector>
然后在对应的控件上,添加属性
android:background="@drawable/button_shape"
即可!
开关
需要添加图片的话,首先在相应分辨率的文件夹下放置图片。
(关于不同文件夹下的不同分辨率,具体了解戳这里!)
  • app/src/main/res/drawable-hdpi
    添加图片:ledon、ledoff
  • `app/src/main/java/包名/MainActivity.java
//设置SWITCH的状态改变事件
switchLamp.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
    @Override
    public void onCheckedChanged(CompoundButton buttonView, boolean isChecked) {
        if (isChecked) {//切换图片
            imageViewLamp.setImageResource(R.drawable.ledon);
        else {
            imageViewLamp.setImageResource(R.drawable.ledoff);
文章来源: recclay.blog.csdn.net,作者:ReCclay,版权归原作者所有,如需转载,请联系作者。
原文链接:recclay.blog.csdn.net/article/details/81395196
