【ESP8266之LUA开发】十一、实战DHT11获取温湿度绘制曲线到APP
ReCclay 发表于 2022/02/22 02:03:11 2022/02/22
【摘要】 链接:https://pan.baidu.com/s/1VA8AX7HV5ykdBvLnK-wTTA 密码:ssmz init.lua --[[ GPIO0--3 GPIO1--10 GPIO...
这里写图片描述
init.lua
GPIO0--3
GPIO1--10
GPIO2--4
GPIO3--9
GPIO4--2
GPIO5--1
GPIO9--11
GPIO10--12
GPIO12--6
GPIO13--7
GPIO14--5
GPIO15--8
GPIO16--0
0--GPIO16   1--GPIO5   2--GPIO4   3--GPIO0   4--GPIO2
5--GPIO14   6--GPIO12  7--GPIO13  8--GPIO15  9--GPIO3
10--GPIO1   11--GPIO9  12--GPIO10
configwifissid = "CMCC_4148";
configwifipwd="61034148";
MqttUserString = "CLAY";
MqttPwdString = "11223344";
MqttIPString = "140.143.4.235";
MqttPort = 1883;
clientid = wifi.sta.getmac()
SubscribeTopic = "/pub"
PublishTopic = "/sub"
RelayPin = 2
wifi.setmode(wifi.STATIONAP)
apcfg={}
apcfg.ssid=configwifissid
apcfg.pwd=configwifipwd
wifi.sta.config(apcfg)
wifi.sta.autoconnect(1)
print("dofile init.lua")
tmr.alarm(0, 3000, 0, function()
   dofile("mqtt.lua");
   print("dofile mqtt.lua")
end)
mqtt.lua
globalSendData ="nil";
globalSendData1="nil";
globalSendData2="nil";
UsartReceiveData="";
UsartReceiveDataCnt=0;
UsartReceiveDataCntCopy=0;
if  file.open("relay.lua", "r") then
    if  file.read() == "relay=1" then
        gpio.write(RelayPin,1)
        gpio.mode(RelayPin,gpio.OUTPUT)
        print("relay=1")
    else
        gpio.write(RelayPin,0)
        print("relay=0")
    end
end
file.close()
Mymqtt = mqtt.Client(clientid, 120,MqttUserString, MqttPwdString);
tmr.alarm(3, 1000, 1, function()
    Mymqtt:connect(MqttIPString, MqttPort, 0,ConnectSuccess,ConnectFailed)
end)
function ConnectSuccess(client)
     client:subscribe(SubscribeTopic, 0, subscribeSuccess)
     print("connected")
     mqttClient = client;
     tmr.stop(3);
     mqttConnectedFlage = 1;
end
function ConnectFailed(client,reason)
   mqttConnectedFlage = 0;
   print("failed reason: " .. reason)
   tmr.start(3)
end
function subscribeSuccess(client)
    print("subscribe success")
end
Mymqtt:on("message", function(client, topic, data)
    uart.write(0,data)
    if data == "switch;relay=0" then
       if  file.open("relay.lua", "w+") then
           file.write("relay=0")
           file.close()
       end
    elseif data == "switch;relay=1"  then
           file.write("relay=1")
           file.close()
       end
    end
end)
tmr.alarm(4, 10, 1, function()
    if  mqttClient ~= nil and mqttConnectedFlage == 1 then
        RelayNowState = gpio.read(RelayPin)
        if  RelayNowState ~= RelayNowStateCopy then
            RelayNowStateCopy = RelayNowState
            globalSendData1 = "relay="..RelayNowState
        end
        if  globalSendData1~="nil" then
            globalSendData=globalSendData1;
        elseif globalSendData2 ~="nil" then
            globalSendData=globalSendData2;
        else
            globalSendData="nil";
        end
        if  globalSendData ~= "nil" then
            mqttClient:publish(PublishTopic,globalSendData, 0, 0, function(client)
            end)
        end
    end
    if UsartReceiveDataCnt ~= 0 then
       if UsartReceiveDataCntCopy == UsartReceiveDataCnt then
          UsartReceiveDataCntCopy = 0;
          globalSendData2 = UsartReceiveData;
       else
          UsartReceiveDataCntCopy = UsartReceiveDataCnt;
       end
    end
end)
uart.setup(0, 115200, 8, uart.PARITY_NONE, uart.STOPBITS_1)
uart.on("data",0,function(data)
    UsartReceiveData = UsartReceiveData..data;
    UsartReceiveDataCnt = UsartReceiveDataCnt + 1;
end, 0)
DHT11pin = 4--DHT11 GPIO
tmr.alarm(6, 2000, 1, function()--Every other 1S
    status, Temperature, Humidity, temp_dec, humi_dec = dht.read11(DHT11pin)--Gathering temperature and humidity
    if  status == dht.OK or status == dht.ERROR_CHECKSUM then
        globalSendData2 = "data;".."Tem="..Temperature..";".."Hum="..Humidity
    elseif status == dht.ERROR_TIMEOUT then
        --print( "DHT timed out." )
    end
end)
文章来源: recclay.blog.csdn.net,作者:ReCclay,版权归原作者所有,如需转载,请联系作者。
原文链接:recclay.blog.csdn.net/article/details/82026161
评论(0
