OTTO机器人之MAX7219点阵
ReCclay 发表于 2022/02/22 01:42:35 2022/02/22
【摘要】 接线 在IN方向的针脚 Arduino Uno — MAX7219 5V <—> VCC GND <—> GND 12 <—> DIN 11 ...
接线
在IN方向的针脚
5V <—> VCC
GND <—> GND
12 <—> DIN
11 <—> CS
10 <—> CLK
所需的库
https://github.com/wayoda/LedControl
代码
#include <LedControl.h>
byte e[8]=     {0x7C,0x7C,0x60,0x7C,0x7C,0x60,0x7C,0x7C};  //E
byte d[8]=     {0x78,0x7C,0x66,0x66,0x66,0x66,0x7C,0x78};  //D
byte u[8]=     {0x66,0x66,0x66,0x66,0x66,0x66,0x7E,0x7E};  //U
byte c[8]=     {0x7E,0x7E,0x60,0x60,0x60,0x60,0x7E,0x7E};  //C
byte eight[8]= {0x7E,0x7E,0x66,0x7E,0x7E,0x66,0x7E,0x7E};  //8
byte s[8]=     {0x7E,0x7C,0x60,0x7C,0x3E,0x06,0x3E,0x7E};  //S
byte dot[8]=   {0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18};  //.
byte o[8]=     {0x7E,0x7E,0x66,0x66,0x66,0x66,0x7E,0x7E};  //O
byte m[8]=     {0xE7,0xFF,0xFF,0xDB,0xDB,0xDB,0xC3,0xC3};  //M
byte smile[8]=   {0x3C,0x42,0xA5,0x81,0xA5,0x99,0x42,0x3C};//笑脸
byte neutral[8]= {0x3C,0x42,0xA5,0x81,0xBD,0x81,0x42,0x3C};//标准脸
LedControl lc=LedControl(12,11,10,4);
void setup(){
	lc.shutdown(0,false);       //启动时,MAX72XX处于省电模式
	lc.setIntensity(0,8);       //将亮度设置为最大值
	lc.clearDisplay(0);         //清除显示
void loop(){
    printByte(smile);//显示8
    delay(1000);//延时1秒
    printByte(neutral);//显示标准脸
    delay(1000);
//点阵显示函数
void printByte(byte character [])
	int i = 0;
	for(i=0;i<8;i++)
		lc.setRow(0,i,character[i]);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
点阵+胳膊
#include <Servo.h>
#include <Oscillator.h>
#include <EEPROM.h>
#include <FlexiTimer2.h>
#define N_SERVOS 6 // 共6个舵机
#define PIN_AR 7 // 右胳膊
#define PIN_AL 6 // 左胳膊
#define PIN_RR 5 // 右脚
#define PIN_RL 4 // 左脚
#define PIN_YR 3 // 右腿
#define PIN_YL 2 // 左腿
#define INTERVALTIME 10.0
Oscillator servo[N_SERVOS];
LedControl lc=LedControl(12,10,11,4);
byte sad[8] = {0x3C,0x42,0xA5,0x81,0x99,0xA5,0x42,0x3C};//悲伤脸
byte tbyte[8] = {0xFF,0xFF,0x18,0x18,0x18,0x18,0x18,0x18};
byte obyte[8]=     {0x7E,0x7E,0x66,0x66,0x66,0x66,0x7E,0x7E};  //O
byte ddd[8] = { 0x00,0x7E,0x81,0x81,0x81,0x81,0x81,0x7E};
byte kkk[8] = {0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x00};
byte xxx[8] = {0x00,0x00,0x3C,0x42,0x42,0x42,0x3C,0x00};
byte zzz[8] = {0x00,0x00,0x7E,0xC3,0x7E,0x00,0x00,0x00};
void goingUp(int tempo);
void drunk (int tempo);
void noGravity(int tempo);
void kickLeft(int tempo);
void kickRight(int tempo);
void run(int steps, int T=500);
void walk(int steps, int T=1000);
void backyard(int steps, int T=3000);
void backyardSlow(int steps, int T=5000);
void turnLeft(int steps, int T=3000);
void turnRight(int steps, int T=3000);
void moonWalkLeft(int steps, int T=1000);
void moonWalkRight(int steps, int T=1000);
void crusaito(int steps, int T=1000);
void swing(int steps, int T=1000);
void upDown(int steps, int T=1000);
void flapping(int steps, int T=1000);
void event()
    static int tmr = 0;
    if(tmr == 0) printByte(kkk);
	if(tmr == 1) printByte(xxx);
	if(tmr == 2) printByte(zzz);
	if(tmr == 3) printByte(xxx);
	if(tmr == 4) printByte(zzz);
	if(tmr == 5) printByte(xxx);
	if(tmr == 6) printByte(zzz);
	if(tmr == 8) printByte(xxx);
	if(tmr == 9) printByte(kkk);
	tmr++;
	if(tmr >= 10)
		tmr = 0;
void setup()
	Serial.begin(9600);
	Serial.println("Hello OTTO~");
	//设置舵机引脚
	servo[0].attach(PIN_RR);
	servo[1].attach(PIN_RL);
	servo[2].attach(PIN_YR);
	servo[3].attach(PIN_YL);
	servo[4].attach(PIN_AR); //右胳膊 90-垂下去、0-平直
	servo[5].attach(PIN_AL); //左胳膊 90-垂下去、180-平直
	for(int i=0;i<6;i++) // 舵机归位
		servo[i].SetPosition(90);
	FlexiTimer2::set(500,1.0/2,event);
    FlexiTimer2::start();
	/*printByte(kkk);
	delay(500);
	printByte(xxx);
	delay(500);
	printByte(zzz);
	delay(500);
	printByte(xxx);
	delay(500);
	printByte(zzz);
	delay(500);
	printByte(xxx);
	delay(500);
	printByte(zzz);
	delay(500);
	printByte(ddd);
	delay(500);
	printByte(xxx);
	delay(500);
	printByte(kkk);
	delay(500);*/
int t=495;
double pause=0;
void loop()
	dance();
//	for(int i=0;i<6;i++) //舵机归位
//		servo[i].SetPosition(90);
//点阵显示函数
  int i = 0;
  for(i=0;i<8;i++)
void dance()
	primera_parte();
	/*segunda_parte();*/
	moonWalkLeft(4,t*2);
	moonWalkRight(4,t*2);
	/*primera_parte();
	crusaito(1,t*8);
	crusaito(1,t*7);/*
	/*for (int i=0; i<16; i++)
		flapping(1,t/4);
		delay(3*t/4);
	moonWalkLeft(4,t*2);*/
	/*drunk(t*4);
	drunk(t*4);
	drunk(t*4);
	drunk(t*4);
	kickLeft(t);
	kickRight(t);
	drunk(t*8);
	drunk(t*4);
	drunk(t/2);
	delay(t*4); */
	/*drunk(t/2);
	delay(t*4);
	walk(2,t*2);
	backyard(2,t*2);
	goingUp(t*2);
	goingUp(t*1);
	noGravity(t*2);
	crusaito(1,t*2);
	crusaito(1,t*8);
	crusaito(1,t*2);
	crusaito(1,t*8);
	crusaito(1,t*2);
	crusaito(1,t*3);*/
	/*delay(t);
	primera_parte();
	for (int i=0; i<32; i++)
		flapping(1,t/2);
		delay(t/2);
	for(int i=0;i<4;i++)
//FUNCIONES DE CONTROL//
void oscillate(int A[N_SERVOS], int O[N_SERVOS], int T, double phase_diff[N_SERVOS]){
  for (int i=0; i<4; i++) {
    servo[i].SetO(O[i]);
    servo[i].SetA(A[i]);
    servo[i].SetT(T);
    servo[i].SetPh(phase_diff[i]);
  double ref=millis();
   for (double x=ref; x<T+ref; x=millis()){
     for (int i=0; i<4; i++){
        servo[i].refresh();
unsigned long final_time;
unsigned long interval_time;
int oneTime;
int iteration;
float increment[N_SERVOS];
int oldPosition[]={90,90,90,90};
void moveNServos(int time, int  newPosition[]){
  for(int i=0;i<N_SERVOS;i++)   increment[i] = ((newPosition[i])-oldPosition[i])/(time/INTERVALTIME);
  final_time =  millis() + time;
  iteration = 1;
  while(millis() < final_time){ //Javi del futuro cambia esto
      interval_time = millis()+INTERVALTIME;
      oneTime=0;
      while(millis()<interval_time){
          if(oneTime<1){
              for(int i=0;i<N_SERVOS;i++){
                  servo[i].SetPosition(oldPosition[i] + (iteration * increment[i]));
              iteration++;
              oneTime++;
    oldPosition[i] = newPosition[i];
PASOS DE BAILE
void goingUp(int tempo){
      pause=millis();
      for(int i=0;i<4;i++) servo[i].SetPosition(90);
      delay(tempo);
      servo[0].SetPosition(80);
      servo[1].SetPosition(100);
      delay(tempo);
      servo[0].SetPosition(70);
      servo[1].SetPosition(110);
      delay(tempo);
      servo[0].SetPosition(60);
      servo[1].SetPosition(120);
      delay(tempo);
      servo[0].SetPosition(50);
      servo[1].SetPosition(130);
      delay(tempo);
      servo[0].SetPosition(40);
      servo[1].SetPosition(140);
      delay(tempo);
      servo[0].SetPosition(30);
      servo[1].SetPosition(150);
      delay(tempo);
      servo[0].SetPosition(20);
      servo[1].SetPosition(160);
      delay(tempo);
      while(millis()<pause+8*t);
void primera_parte(){
  int move1[4] = {60,120,90,90};
  int move2[4] = {90,90,90,90};
  int move3[4] = {40,140,90,90};
  for(int x=0; x<3; x++){
    for(int i=0; i<3; i++){
      lateral_fuerte(1,t/2);
      lateral_fuerte(0,t/4);
      lateral_fuerte(1,t/4);
      delay(t);
    pause=millis();
    moveNServos(t*0.4,move1);
    moveNServos(t*0.4,move2);
    while(millis()<(pause+t*2));
  for(int i=0; i<2; i++){
    delay(t);
  /*pause=millis();
  crusaito(1,t*1.4);
  moveNServos(t*1,move3);
  while(millis()<(pause+t*4));*/
void segunda_parte(){
  int move1[4] = {90,90,80,100};
  int move2[4] = {90,90,100,80};
  int move3[4] = {90,90,80,100};
  int move4[4] = {90,90,100,80};
  int move5[4] = {40,140,80,100};
  int move6[4] = {40,140,100,80};
  int move7[4] = {90,90,80,100};
  int move8[4] = {90,90,100,80};
  int move9[4] = {40,140,80,100};
  int move10[4] = {40,140,100,80};
  int move11[4] = {90,90,80,100};
  int move12[4] = {90,90,100,80};
  for(int x=0; x<7; x++){
      pause=millis();
      moveNServos(t*0.15,move1);
      moveNServos(t*0.15,move2);
      moveNServos(t*0.15,move3);
      moveNServos(t*0.15,move4);
      while(millis()<(pause+t));
    pause=millis();
    moveNServos(t*0.15,move5);
    moveNServos(t*0.15,move6);
    moveNServos(t*0.15,move7);
    moveNServos(t*0.15,move8);
    pause=millis();
    moveNServos(t*0.15,move9);
    moveNServos(t*0.15,move10);
    moveNServos(t*0.15,move11);
    moveNServos(t*0.15,move12);
void lateral_fuerte(boolean side, int tempo)
	for(int i=0;i<6;i++)//舵机归位
	if (side)
	else
	delay(tempo/2);
	servo[0].SetPosition(90);
	servo[1].SetPosition(90);
	delay(tempo/2);
void drunk (int tempo){
  pause=millis();
  int move1[] = {60,70,90,90};
  int move2[] = {110,120,90,90};
  int move3[] = {60,70,90,90};
  int move4[] = {110,120,90,90};
  moveNServos(tempo*0.235,move1);
  moveNServos(tempo*0.235,move2);
  moveNServos(tempo*0.235,move3);
  moveNServos(tempo*0.235,move4);
  while(millis()<(pause+tempo));
void noGravity(int tempo){
  int move1[4] = {120,140,90,90};
  int move2[4] = {140,140,90,90};
  int move3[4] = {120,140,90,90};
  int move4[4] = {90,90,90,90};
  for(int i=0;i<N_SERVOS;i++) oldPosition[i]=90;
  moveNServos(tempo*2,move1);
  moveNServos(tempo*2,move2);
  delay(tempo*2);
  moveNServos(tempo*2,move3);
  moveNServos(tempo*2,move4);
void kickLeft(int tempo){
  delay(tempo);
  servo[0].SetPosition(50); //pie derecho
  servo[1].SetPosition(70); //pie izquiero
  delay(tempo);
  servo[0].SetPosition(80); //pie derecho
  delay(tempo/4);
  servo[0].SetPosition(30); //pie derecho
  delay(tempo/4);
  delay(tempo/4);
  delay(tempo/4);
  delay(tempo);
void kickRight(int tempo){
  delay(tempo);
  servo[0].SetPosition(110); //pie derecho
  servo[1].SetPosition(130); //pie izquiero
  delay(tempo);
  servo[1].SetPosition(100); //pie izquiero
  delay(tempo/4);
  servo[1].SetPosition(150); //pie izquiero
  delay(tempo/4);
  servo[1].SetPosition(80); //pie izquiero
  delay(tempo/4);
  delay(tempo/4);
  delay(tempo);
void walk(int steps, int T){
    int A[4]= {15, 15, 30, 30};
    int O[4] = {0, 0, 0, 0};
    double phase_diff[4] = {DEG2RAD(0), DEG2RAD(0), DEG2RAD(90), DEG2RAD(90)};
    for(int i=0;i<steps;i++)oscillate(A,O, T, phase_diff);
void run(int steps, int T){
    int A[4]= {10, 10, 10, 10};
void backyard(int steps, int T){
    double phase_diff[4] = {DEG2RAD(0), DEG2RAD(0), DEG2RAD(-90), DEG2RAD(-90)};
void backyardSlow(int steps, int T){
void turnLeft(int steps, int T){
    int A[4]= {20, 20, 10, 30};
void turnRight(int steps, int T){
    int A[4]= {20, 20, 30, 10};
void moonWalkRight(int steps, int T){
    int A[4]= {25, 25, 0, 0};
    int O[4] = {-15 ,15, 0, 0};
    double phase_diff[4] = {DEG2RAD(0), DEG2RAD(180 + 120), DEG2RAD(90), DEG2RAD(90)};
void moonWalkLeft(int steps, int T){
    int O[4] = {-15, 15, 0, 0};
    double phase_diff[4] = {DEG2RAD(0), DEG2RAD(180 - 120), DEG2RAD(90), DEG2RAD(90)};
void crusaito(int steps, int T){
    int A[4]= {25, 25, 30, 30};
    int O[4] = {- 15, 15, 0, 0};
void swing(int steps, int T){
void upDown(int steps, int T){
    double phase_diff[4] = {DEG2RAD(180), DEG2RAD(0), DEG2RAD(270), DEG2RAD(270)};
void flapping(int steps, int T){
    int A[4]= {15, 15, 8, 8};
    int O[4] = {-A[0], A[1], 0, 0};
    double phase_diff[4] = {DEG2RAD(0), DEG2RAD(180), DEG2RAD(90), DEG2RAD(-90)};
void test(int steps, int T){
    int O[4] = {-A[0] + 10, A[1] - 10, 0, 0};
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
  • 330
  • 331
  • 332
  • 333
  • 334
  • 335
  • 336
  • 337
  • 338
  • 339
  • 340
  • 341
  • 342
  • 343
  • 344
  • 345
  • 346
  • 347
  • 348
  • 349
  • 350
  • 351
  • 352
  • 353
  • 354
  • 355
  • 356
  • 357
  • 358
  • 359
  • 360
  • 361
  • 362
  • 363
  • 364
  • 365
  • 366
  • 367
  • 368
  • 369
  • 370
  • 371
  • 372
  • 373
  • 374
  • 375
  • 376
  • 377
  • 378
  • 379
  • 380
  • 381
  • 382
  • 383
  • 384
  • 385
  • 386
  • 387
  • 388
  • 389
  • 390
  • 391
  • 392
  • 393
  • 394
  • 395
  • 396
  • 397
  • 398
  • 399
  • 400
  • 401
  • 402
  • 403
  • 404
  • 405
  • 406
  • 407
  • 408
  • 409
  • 410
  • 411
  • 412
  • 413
  • 414
  • 415
  • 416
  • 417
  • 418
  • 419
  • 420
  • 421
  • 422
  • 423
  • 424
  • 425
  • 426
  • 427
  • 428
  • 429
  • 430
  • 431
  • 432
  • 433
  • 434
  • 435
  • 436
  • 437
  • 438
  • 439
  • 440
  • 441
  • 442
  • 443
  • 444
  • 445
  • 446
  • 447
  • 448
  • 449
  • 450
  • 451
  • 452
  • 453
  • 454
  • 455
  • 456
  • 457
  • 458
  • 459
  • 460
  • 461
  • 462
  • 463
  • 464
  • 465
  • 466
  • 467
  • 468
  • 469
  • 470
  • 471
  • 472
  • 473
  • 474
  • 475
  • 476
  • 477
  • 478
  • 479
  • 480
  • 481
  • 482
  • 483
  • 484
  • 485
  • 486
  • 487
  • 488
  • 489
  • 490
  • 491
  • 492
  • 493
  • 494
  • 495
  • 496
  • 497
  • 498
  • 499
  • 500
  • 501
  • 502
  • 503
  • 504
  • 505
  • 506
  • 507
  • 508
  • 509
  • 510
  • 511
  • 512
  • 513
  • 514
  • 515
  • 516
  • 517
  • 518
  • 519
  • 520
  • 521
  • 522
  • 523
  • 524
  • 525
  • 526
  • 527
  • 528
  • 529
  • 530
  • 531
  • 532
  • 533
  • 534
  • 535
  • 536
  • 537
  • 538
  • 539
  • 540
  • 541
  • 542
  • 543
  • 544
  • 545
  • 546
  • 547
  • 548
  • 549
  • 550
  • 551
  • 552
  • 553
  • 554
  • 555
  • 556
  • 557
  • 558
  • 559
  • 560
  • 561
  • 562
  • 563
  • 564
  • 565
  • 566
  • 567
  • 568
  • 569
  • 570
  • 571
  • 572
  • 573
  • 574
  • 575
  • 576
  • 577
  • 578
  • 579
文章来源: recclay.blog.csdn.net,作者:ReCclay,版权归原作者所有,如需转载,请联系作者。
原文链接:recclay.blog.csdn.net/article/details/82800143
