算法 - 随机密码生成算法
简简单单Onlinezuozuo 发表于 2022/02/18 23:23:09 2022/02/18
【摘要】 算法 - 随机密码生成算法 import java.util.Random; /** * Created by 谭健 on 2017/10/16. 11:13. * © All Rights ...
算法 - 随机密码生成算法
 * © All Rights Reserved.
public class Password {
    public Password() {
    // 提供强度的构造方法
    public Password(int strengthLevel, int length) {
        this.strengthLevel = strengthLevel;
        this.length = length;
     * Password level config
     * 1 level : only number
     * 2 level : number and lowercase letters
     * 3 level : number , lowercase letters , capital letters
     * 4 level : number , lowercase letters , capital letters , special characters
    private int strengthLevel = 4;
    // 需要的密码长度
    private int length = 6;
    private static final Random RANDOM = new Random();
    // getter and setter
    public int getLength() {
        return length;
    public void setLength(int length) {
    public int getStrengthLevel() {
        return strengthLevel;
    public void setStrengthLevel(int strengthLevel) {
    // 用char类型是因为char类型效率比数组方式要高
    // 因为伪随机数random在nextInt()的时候会出现向更小的数偏离的情况,所以用一个randomMax来修正
    private static final int randomMax = 100000000;
    // 因为数组下标从0开始
    private static final int index = 1;
    // 一共26个字母
    private static final int numberOfLetter = 26;
    // ascii码表数字从48开始
    private static final int nunberIndex = 48;
    // 数组下标0-9代表10个数字
    private static final int numberMax = 9;
    // 大写字母ascii码表从65开始
    private static final int capitalIndex = 65;
    // 小写字母ascii码表从65开始
    private static final int lowercaseIndex = 97;
    // 特殊字符的起始ascii码表序号取第一个数字
    private static final int special = 0;
    // 特殊字符集,第一个数字代表ascii码表序号,第二个代表从这里开始一共使用多少个字符
    private static final int[][] specialCharacter = {{33, 14}, {58, 6}, {91, 5}, {123, 3}};
    // 取随机密码
    public String getRandomPassword() throws Exception {
        StringBuffer buffer = new StringBuffer();
        if (length <= 0)
            throw new Exception("length can not <= 0");
        for (int i = 0; i < length; i++)
            buffer.append((char) getNextChar());
        return buffer.toString();
    // 取得下一个ascii编码
    private int getNextChar() throws Exception {
        if (strengthLevel < 1 || strengthLevel > 4)
            throw new Exception("This level is not supported");
        // ascii编码
        int x = 0;
        // 伪字符ascii编码
        final int puppetLetter = RANDOM.nextInt(randomMax) % numberOfLetter;
        // 伪数字ascii编码
        final int puppetNumber = RANDOM.nextInt(randomMax) % numberMax + nunberIndex;
        // 按照字符等级强度取ascii值
        final int levelIndex = RANDOM.nextInt(randomMax) % strengthLevel;
        // 特殊字符的随机集合下标(数组第一维)
        final int specialType = RANDOM.nextInt(randomMax) % specialCharacter.length;
        // 特殊字符的ascii编码
        final int specialInt = RANDOM.nextInt(randomMax) % specialCharacter[specialType][index] + specialCharacter[specialType][special];
        // 根据密码强度等级获取随机ascii编码
        switch (strengthLevel) {
            case 1:
                x = puppetNumber;
                break;
            case 2:
                if (levelIndex == index)
                    x = puppetNumber;
                else
                    x = puppetLetter + lowercaseIndex;
                break;
            case 3:
                if (levelIndex == 0)
                    x = puppetNumber;
                else if (levelIndex == index)
                else
                    x = puppetLetter + capitalIndex;
                break;
            case 4:
                    x = puppetNumber;
                else if (levelIndex == index * 2)
                else
                    x = specialInt;
                break;
            default:
        return x;
        System.out.println(System.currentTimeMillis());
        Password password = new Password();
        for (int i = 0; i < 10000; i++)
            try {
                System.out.println(password.getRandomPassword());
            } catch (Exception e) {
                e.printStackTrace();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
文章来源: wretchant.blog.csdn.net,作者:简简单单OnlineZuozuo,版权归原作者所有,如需转载,请联系作者。
原文链接:wretchant.blog.csdn.net/article/details/78248575
