SpringBoot项目取消数据库配置
简简单单Onlinezuozuo 发表于 2022/02/19 00:55:25 2022/02/19
【摘要】 SpringBoot项目取消数据库配置 1. 错误 springboot项目启动时,如果没有配置数据库配置,启动时会抛出如下异常。 Description: Cannot determine ...
SpringBoot项目取消数据库配置
1. 错误
Description:
Cannot determine embedded database driver class for database type NONE
Action:
If you want an embedded database please put a supported one on the classpath.
If you have database settings to be loaded from a particular profile you may
need to active it (no
文章来源: wretchant.blog.csdn.net,作者:简简单单OnlineZuozuo,版权归原作者所有,如需转载,请联系作者。
原文链接:wretchant.blog.csdn.net/article/details/78458890
