Linux 参数之 max_map_count
简简单单Onlinezuozuo 发表于 2022/02/18 22:15:33 2022/02/18
【摘要】 文章目录 Linux 参数之 max_map_count 1、原文 2、译文 ...
1、原文
“This file contains the maximum number of memory map areas a process may have. Memory map areas are used as a side-effect of calling malloc, directly by mmap and mprotect, and also when loading shared libraries.
While most applications need less than a thousand maps, certain programs, particularly malloc debuggers, may consume lots of them, e.g., up to one or two maps per allocation.
The default value is 65536.”
文章来源: wretchant.blog.csdn.net,作者:简简单单OnlineZuozuo,版权归原作者所有,如需转载,请联系作者。
原文链接:wretchant.blog.csdn.net/article/details/109055602
