布隆过滤器原理(有眼睛就能看懂)
负债程序猿 发表于 2022/02/18 23:42:55 2022/02/18
【摘要】 作用嘛就是用来过滤非法key,避免缓存穿透(请求直接打到数据库),布隆过滤器底层用的是位数组,不仅节省空间,性能也嘎嘎猛,而且占用内存不会随着使用变大 先贴demo后BB public class M...
先贴demo后BB
public class MyBloomFilter {
    //后面hash函数会用到,用来生成不同的hash值,可以随便给,但别给奇数
    private final int[] ints = {6, 8, 16, 38, 58, 68};
    private Integer currentBeanCount = 0;
    //你的布隆过滤器容量
    private int DEFAULT_SIZE = Integer.MAX_VALUE;
    //bit数组,用来存放结果
    private final BitSet bitSet = new BitSet(DEFAULT_SIZE);
    public MyBloomFilter() {
    public MyBloomFilter(int size) {
        if (size > Integer.MAX_VALUE) throw new RuntimeException("size is too large");
        if (size <= (2 << 8)) throw new RuntimeException("size is too small");
        DEFAULT_SIZE = size;
	//获取当前过滤器的对象数量
    public Integer getCurrentBeanCount() {
        return currentBeanCount;
    //计算出key的hash值,并将对应下标置为true
    public void push(Object key) {
        Arrays.stream(ints).forEach(i -> bitSet.set(hash(key, i)));
        currentBeanCount++;
    //判断key是否存在,true不一定说明key存在,但是false一定说明不存在
    public boolean contain(Object key) {
        boolean result = true;
        for (int i : ints) {
            result = result && bitSet.get(hash(key, i));
        return result;
    //hash算法,借鉴了hashmap的算法
    private int hash(Object key, int i) {
        int h;
        int index = key == null ? 0 : (DEFAULT_SIZE - 1 - i) & ((h = key.hashCode()) ^ (h >>> 16));
        return index > 0 ? index : -index;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
测试
        MyNewBloomFilter myNewBloomFilter = new MyNewBloomFilter();
        myNewBloomFilter.add("张学友");
        myNewBloomFilter.add("郭德纲");
        myNewBloomFilter.add("蔡徐鸡");
        myNewBloomFilter.add(666);
        System.out.println(myNewBloomFilter.isContain("张学友"));//true
        System.out.println(myNewBloomFilter.isContain("张学友 "));//false
        System.out.println(myNewBloomFilter.isContain("张学友1"));//false
        System.out.println(myNewBloomFilter.isContain("郭德纲"));//true
        System.out.println(myNewBloomFilter.isContain("蔡徐老母鸡"));//false
        System.out.println(myNewBloomFilter.isContain(666));//true
        System.out.println(myNewBloomFilter.isContain(888));//false
原理
通过对比hash算法计算出来的下标,注意,我们是对比一组,而不是只看一次,一次hash结果对应一个下标
把同一个key进行多次hash运算,将hash出来的下标放入数组,数组默认全为0,放入元素后该下标就为1,后面判断是否存在元素的时候也是进行同样次数的hash运算,看下结果对应的所有下标是否全为1,若全为1,则代表该key可能存在,若存在不为1的,则说明该key一定不存在;
默认位数组:[0,0,0,0,0,0]
比方说有个已知key的下标是0,2,5
对应位数组:[1,0,1,0,0,1]
判断某个未知key存不存在的时候,假设我们计算出来的下标是0,2,4
对应位数组:[1,0,1,0,1,0]
此时位数组内5对应下标值为0,而已知key位数组的5对应下标位1,说明这两个一定不是同一个key
相反,如果某个key计算出来的下标为[1,0,1,0,0,1],只能说这个key可能存在,因为这个位置可能是其它key计算出来的
如果对上面的hash算法有疑惑,请移步帮你真正理解hashCode和hash算法
demo复制可用,家里有条件的都在编译器上跑一跑,测一测
ok我话讲完
嘤嘤嘤~
文章来源: huangjie.blog.csdn.net,作者:负债程序猿,版权归原作者所有,如需转载,请联系作者。
原文链接:huangjie.blog.csdn.net/article/details/108407706
