Oracle获取表字段名,字段类型,字段长度,注释
经典鸡翅 发表于 2022/02/18 00:50:42 2022/02/18
【摘要】 SELECT b.comments as 注释, a.column_name as 列名, a.data_type || '(' || a.data_length || ')' as 数据类型, a.nullable as 是否为空 FROM user_tab_columns a, u...
  1. SELECT b.comments as 注释,
  2. a.column_name as 列名,
  3. a.data_type || '(' || a.data_length || ')' as 数据类型,
  4. a.nullable as 是否为空
  5. FROM user_tab_columns a, user_col_comments b
  6. WHERE a.TABLE_NAME = '表名'
  7. and b.table_name = '表名'
  8. and a.column_name = b.column_name
文章来源: blog.csdn.net,作者:经典鸡翅,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/hanqing456/article/details/111879018
