tomcat的jsp页面超过65535,导致500报错
经典鸡翅 发表于 2022/02/18 00:25:01 2022/02/18
【摘要】 错误信息 org.apache.jasper.JasperException: Unable to compile class for JSP: An error occurred at line: 158 in the generated java file The code of method _jspService(Ht...
错误信息
  1. org.apache.jasper.JasperException: Unable to compile class for JSP:
  2. An error occurred at line: 158 in the generated java file
  3. The code of method _jspService(HttpServletRequest, HttpServletResponse) is exceeding the 65535 bytes limit.
解决办法
找到tomcat的web.xml文件,搜索fork,找到如下代码
  1. <servlet>
  2. <servlet-name>jsp</servlet-name>
  3. <servlet-class>org.apache.jasper.servlet.JspServlet</servlet-class>
  4. <init-param>
  5. <param-name>fork</param-name>
  6. <param-value>false</param-value>
  7. </init-param>
  8. <init-param>
  9. <param-name>xpoweredBy</param-name>
  10. <param-value>false</param-value>
  11. </init-param>
  12. <load-on-startup>3</load-on-startup>
  13. </servlet>
增加配置
  1. <init-param>
  2. <param-name>mappedfile</param-name>
  3. <param-value>false</param-value>
  4. </init-param>
文章来源: blog.csdn.net,作者:经典鸡翅,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/hanqing456/article/details/111878842
