webpack5构建一个小型简单vue项目 (练习)
代码哈士奇 发表于 2022/01/31 08:34:07 2022/01/31
【摘要】 webpack5构建一个小型简单vue项目 (练习)
webpack5构建vue
必要环境
安装ndejs
我们需要安装node 如果没有安装则安装 安装过则跳过
下载安装nodejs
执行
node -v
npm -v
初始化项目文件夹
新建一个空的项目
执行 npm init -y 初始化
npm init -y
会生成一个package.json
安装webpack以及 html-webpack-plugin
控制台执行
npm i webpack webpack-cli webpack-dev-server html-webpack-plugin -D
安装babel-loader
babel可以将我们的代码向下适配
npm i babel-loader @babel/core @babel/preset-env @babel/polyfill core-js@3 -D
安装 css-lodaer
支持less
npm install css-loader style-loader sass-loader postcss-loader autoprefixer less-loader  -D
安装 mini-css-extract-plugin css-minimizer-webpack-plugin
用来抽离压缩css 代码
npm i mini-css-extract-plugin css-minimizer-webpack-plugin -D
项目依赖 (面还有需要安装的)
 "devDependencies": {
    "@babel/core": "^7.16.12",
    "@babel/polyfill": "^7.12.1",
    "@babel/preset-env": "^7.16.11",
    "@element-plus/icons": "^0.0.11",
    "@vue/cli-plugin-babel": "^4.5.15",
    "@vue/compiler-sfc": "^3.2.29",
    "autoprefixer": "^10.4.2",
    "babel-eslint": "^10.1.0",
    "babel-loader": "^8.2.3",
    "copy-webpack-plugin": "^10.2.1",
    "core-js": "^3.20.3",
    "css-loader": "^6.5.1",
    "css-minimizer-webpack-plugin": "^3.4.1",
    "element-plus": "^1.3.0-beta.9",
    "eslint": "^7.32.0",
    "eslint-loader": "^4.0.2",
    "eslint-plugin-vue": "^8.4.0",
    "file-loader": "^6.2.0",
    "html-webpack-plugin": "^5.5.0",
    "less-loader": "^10.2.0",
    "lodash": "^4.17.21",
    "mini-css-extract-plugin": "^2.5.3",
    "postcss-loader": "^6.2.1",
    "sass": "^1.26.5",
    "sass-loader": "^8.0.2",
    "style-loader": "^3.3.1",
    "terser-webpack-plugin": "^5.3.0",
    "unplugin-auto-import": "^0.5.11",
    "unplugin-vue-components": "^0.17.15",
    "url-loader": "^4.1.1",
    "vue": "^3.2.29",
    "vue-loader": "^16.1.0",
    "vue-router": "^4.0.12",
    "vue-style-loader": "^4.1.3",
    "vuex": "^4.0.2",
    "webpack": "^5.67.0",
    "webpack-cli": "^4.9.2",
    "webpack-dev-server": "^4.7.3"
创建多个目录
创建多个文件夹 方便存放不同资源 参考vue-cli脚手架生成的
根目录下新建 webpack.config.js
src下创建main.ts 以及 App.vue
如下
public 目录下
我们放入一个ico文件
创建模板 html文件
webpack5内置了clean output开启即可
在 public目录下新建 index.html
<!DOCTYPE html>
<html lang="">
<head>
    <meta charset="UTF-8">
    <link rel="icon" href="<%= BASE_URL %>favicon.ico">
    <title><%= htmlWebpackPlugin.options.title %></title>
</head>
<body>
<noscript>
    <strong><%= htmlWebpackPlugin.options.title %>:请检查js是否正常启用</strong>
</noscript>
<div id="app"></div>
</body>
</html>
开始构建vue项目
安装 vue-loader等
npm i vue-loader vue-template-compiler vue@next  vuex@next vue-router@next -D
npm install terser-webpack-plugin copy-webpack-plugin -D
配置webpack
webpack5内置了 clean 和 热更新
开启方式 在devServer配置
devServer: {
   hot: true,
   liveReload: true
在 webpack.config.js 文件中
const path = require('path')
const HtmlWebpackPlugin = require('html-webpack-plugin')
const { VueLoaderPlugin } = require('vue-loader')
const MiniCssExtract = require('mini-css-extract-plugin')
const CssMinimizerPlugin = require('css-minimizer-webpack-plugin') //生产环境
const TerserPlugin = require('terser-webpack-plugin')
const CopyWebpackPlugin = require('copy-webpack-plugin')
module.exports = (env) => {
  return {
    devServer: {
      port: 8888,
      hot: true,
      liveReload: true
    mode: env.development ? 'development' : 'production',
    resolve: {
      alias: {
        '@': path.resolve(__dirname, './src')
    entry: './src/main.js',
    output: {
      filename: "js/[name].[contenthash].js",
      // path: path.resolve(__dirname, 'dist/js'),
      clean: true,
      publicPath: "./"
    module: {
      rules: [
          test: /\.vue$/,
          loader: 'vue-loader'
          test: /\.js$/,
          exclude: file => (
            /node_modules/.test(file) &&
            !/\.vue\.js/.test(file)
          use: [
              loader: 'babel-loader',
              options: {
                presets: [
                    '@babel/preset-env',
                      targets: [
                        'last 1 version', //浏览器最新的一个版本
                        '> 1%' //代码使用超过1%
                      useBuiltIns: 'usage',
                      corejs: 3
              loader: "eslint-loader"
          test: /\.(css|scss)$/,
          use: [env.development ? 'vue-style-loader'
            : MiniCssExtract.loader,
              loader: 'css-loader'
              loader: 'sass-loader'
          test: /\.(woff|woff2|eot|ttf|otf)$/,
          type: 'asset/resource'
          test: /\.(png|jpg|gif)$/,
          use: [
              loader: "file-loader",
              options: {
    optimization: {
      minimizer: [
        new CssMinimizerPlugin(),
        new TerserPlugin()
    plugins: [
      new HtmlWebpackPlugin({
        title: "小型vue应用",
        template: "public/index.html",
        filename: "index.html",
        baseUrl: './icon/favicon.ico'
      new CopyWebpackPlugin({
        patterns:[
            to: path.resolve(__dirname, './dist/icon'),
      new MiniCssExtract({
        filename: 'css/style.css'
      new VueLoaderPlugin()
修改package.json
初始化 eslint
eslint --init
选择 检查找到问题
选择 js 浏览器环境 不用ts
拆分配置文件
开发环境
module.exports = {
  devServer: {
    port: 8888,
    hot: true,
    liveReload: true
  mode: 'development',
  resolve: {
    alias: {
  output: {
    publicPath: "/"
  module: {
    rules: [
        test: /\.vue$/,
        test: /\.js$/,
        exclude: file => (
        use: [
            options: {
              presets: [
                    targets: [
                      '> 1%' //代码使用超过1%
                    corejs: 3
        use: ['vue-style-loader',
            // options: {
            //   modules:{
            //     localIdentName: '[local]_[hash:base64:8]'
            // options: {
            //   // sass-loader version >= 8
            //   sassOptions: {
            //     indentedSyntax: true
        use: [
          //   loader:'url-loader',
          //   options:{
          //     limit:4096,
          //     outputPath:'./img',
          //     name:'[name].[hash].[ext]',
            options: {
  plugins: [
      title: "小型vue应用",
生产环境
module.exports = () => {
  return {
    mode: 'production',
    resolve: {
      alias: {
    output: {
      clean: true,
      publicPath: "./"
    module: {
      rules: [
          test: /\.vue$/,
          test: /\.js$/,
          exclude: file => (
          use: [
              options: {
                presets: [
                      targets: [
                        '> 1%' //代码使用超过1%
                      corejs: 3
          use: [ MiniCssExtract.loader,
              // options: {
              //   modules:{
              // options: {
              //   sassOptions: {
          use: [
            //   options:{
            //     limit:4096,
              options: {
    optimization: {
      minimizer: [
        new TerserPlugin()
    plugins: [
        title: "小型vue应用",
        patterns:[
测试
文件夹的基础文件 我复制的通过vue-cli创建的项目
运行
npm run start
打包
npm run build
拓展
这只是一个简单的项目
我们可以增加插件等赋予它更多能力
还有很多需要优化的地方
比如配置文件可以通过合并来优化
开发环境减少插件使用等等
