C#MUD英雄大作战(副源码文件连接)
红目香薰 发表于 2022/01/30 14:00:46 2022/01/30
【摘要】 ​目录开发环境:编码源码地址:开发环境:系统环境:Win10开发工具:VS2019语言:C#项目:控制台应用(.NET Framework)​编码英雄类:(更换namespace即可)using System;namespace demos_oop_5{ /// <summary> /// 封装英雄信息的封装 /// </summary> public class H...
目录
开发环境:
编码
源码地址:
开发环境:
系统环境:Win10
开发工具:VS2019
语言:C#
编码
英雄类:(更换namespace即可)
using System;
    /// <summary>
    /// 封装英雄信息的封装
    /// </summary>
    public class Heros
        private string id;
        private string name;
        private int HP;
        private int AC;
        private string Introduce;
        public Heros()
        /// <summary>
        /// 用于赋值的构造函数
        /// </summary>
        /// <param name="id"></param>
        /// <param name="name"></param>
        /// <param name="hP"></param>
        /// <param name="aC"></param>
        /// <param name="introduce"></param>
        public Heros(string id, string name, int hP, int aC, string introduce)
            this.id = id;
            this.name = name;
            HP = hP;
            AC = aC;
            Introduce = introduce;
        public string Id { get => id; set => id = value; }
        public string Name { get => name; set => name = value; }
        public int HP1 { get => HP; set => HP = value; }
        public int AC1 { get => AC; set => AC = value; }
        public string Introduce1 { get => Introduce; set => Introduce = value; }
执行类:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
    class Program
        /// <summary>
        /// 声明英雄集合变量list
        /// </summary>
        static List<Heros> list = new List<Heros>();
        static Heros one = new Heros();
        static Heros Two = new Heros();
        static void Main(string[] args)
            //英雄对战小游戏
            //*封装*、继承、*构造方法传参*、*while+switch*、*集合、泛型*
            //随机数,数学函数
            Console.WriteLine("**************************");
            Console.WriteLine("*****欢迎来到德莱联盟*****");
            Console.WriteLine("*****英雄对战操作平台*****");
            Console.WriteLine("请对以下功能进行选择性操作");
            while (true)
                Console.WriteLine("******1、查看英雄列表*****");
                Console.WriteLine("******2、选择对战英雄*****");
                Console.WriteLine("******3、开始对战游戏*****");
                Console.WriteLine("******4、立即退出游戏*****");
                string choose = Console.ReadLine();
                switch (choose)
                    case "1": findAll(); break;
                    case "2": peoVSme(); break;
                    case "3": HeroVs(); break;
                    case "4":
                        Console.WriteLine("游戏结束");
                        return;
                    default:
                        Console.WriteLine("请按照菜单操作");
                        break;
        /// <summary>
        /// 英雄对战方法
        /// </summary>
        private static void HeroVs()
            //开战之前一定要重置一下英雄数据,否则血量不足
            findAll();//调用就相当于重置
            Random ra = new Random();
            //one vs two
            Console.WriteLine("对战英雄:"+one.Name+"\tVS\t"+Two.Name);
            Console.WriteLine("*************************");
            while (true)
                //人对机器造成伤害
                Console.Write(one.Name+"\t对\t"+Two.Name+"发动攻击造成:");
                //生成对战的信息,需要全部显示出来
                int toTwo = ra.Next(one.AC1 / 2) + one.AC1 / 2;
                Two.HP1-= toTwo;
                Console.WriteLine(toTwo+"点伤害,\t"+Two.Name+"\t剩余血量:"+Two.HP1);
                if (Two.HP1 <= 0)//机器人是否死亡判断
                    Console.WriteLine(one.Name + "胜利");
                    break;
                //机器对人造成伤害
                Console.Write(Two.Name + "\t对\t" + one.Name + "发动攻击造成:");
                //生成对战的信息,需要全部显示出来
                int toOne = ra.Next(Two.AC1 / 2) + Two.AC1 / 2;
                one.HP1 -= toOne;
                Console.WriteLine(toOne + "点伤害,\t" + one.Name + "\t剩余血量:" + one.HP1);
                //判断是否结束循环
                if (one.HP1<=0) {
                    Console.WriteLine(Two.Name+"胜利");
                    break;
        /// <summary>
        /// 人机选择
        /// </summary>
        private static void peoVSme()
            ///人选
            Console.WriteLine("请输入选择英雄角色编号");
            string peo = Console.ReadLine();
            foreach (var item in list)
                if (item.Id.Equals(peo))
                    one = item;
                    break;
            //机选
            Two = list[ra.Next(3)];
            Console.WriteLine("选择成功");
            Console.WriteLine("您选择的英雄是:" + one.Name);
            Console.WriteLine("电脑选择的英雄是:" + Two.Name);
        private static void findAll()
            //list集合的初始化操作
            list = GetDefaultList();
                Console.Write(item.Id + "\t");
                Console.Write(item.Name + "\t");
                Console.Write(item.HP1 + "\t");
                Console.Write(item.AC1 + "\t");
                Console.Write(item.Introduce1 + "\t");
                Console.WriteLine();
        /// <summary>
        /// 默认的英雄集合
        /// </summary>
        /// <returns></returns>
        public static List<Heros> GetDefaultList()
            List<Heros> heros = new List<Heros>();
            heros.Add(new Heros(System.Guid.NewGuid().ToString("N"), "亚瑟", 860, 80, "亚瑟王~审判之剑"));
            heros.Add(new Heros(System.Guid.NewGuid().ToString("N"), "冰女", 520, 120, "飞箭"));
            heros.Add(new Heros(System.Guid.NewGuid().ToString("N"), "剑圣", 660, 110, "飞斩"));
            return heros;
测试效果:
演示完毕。
源码地址:
【C#MUD_英雄大作战.rar-其他文档类资源-CSDN下载】
