Hybris服务器启动日志分析
汪子熙 发表于 2022/01/30 10:26:57 2022/01/30
【摘要】 build文件检测,使用b2c_acc recipit启动服务器:/home/jerrywang/Hybris/installer/recipes/b2c_acc/build.gradleThe Task.leftShift(Closure) method has been deprecated and is scheduled to be removed in Gradle 5.0. Pl...
The Task.leftShift(Closure) method has been deprecated and is scheduled to be removed in Gradle 5.0. Please use Task.doLast(Action) instead.
at build_24qda9aair3teyrqc9izdrv89.run(/home/jerrywang/Hybris/installer/recipes/b2c_acc/build.gradle:79)
:recipes/b2c_acc:start
Executing: createConfig…
Buildfile: /home/jerrywang/Hybris/hybris/bin/platform/build.xml
clipboard1,1
简单的启动环境检测,比如操作系统,jdk类型,Java编译器类型等等:
clipboard2,2
列出对应文件目录的位置:
[echo] Extension file used: /home/jerrywang/Hybris/hybris/config/localextensions.xml
[echo] Platform home: /home/jerrywang/Hybris/hybris/bin/platform
[echo] Lg folder: /home/jerrywang/Hybris/hybris/log
[echo] Data folder: /home/jerrywang/Hybris/hybris/data
[echo] Config folder: /home/jerrywang/Hybris/hybris/config
[echo] Bin folder: /home/jerrywang/Hybris/hybris/bin
[echo] Temp folder: /home/jerrywang/Hybris/hybris/temp/hybriso
[echo] Boostrap bin folder: /home/jerrywang/Hybris/hybris/bin/platform/bootstrap/bin
列出加载的extension和module名称:
clipboard3,3
clipboard4,4
Tenant名称,启动模式,操作系统类型,数据库类型和存储文件,Java版本,Cache,web server类型都打印出来了:
clipboard5,5
启动Solr服务器,端口8983:
clipboard6,6
等待3分钟,直到Solr成功启动为止,看到Happy searching, 意味着稍后可以使用full text query了。
clipboard7,7
接下来是Spring开发程序员熟悉的context refresh操作了:
clipboard8,8
[localhost-startStop-2] [HybrisContextFactory] - Refreshing SpringContext (Global context) took: (7.980 s)
[m[32mINFO [localhost-startStop-2] [HybrisContextFactory] Initializing <<global>> Spring ApplicationContext took: (8.708 s)
[m[32mINFO [localhost-startStop-2] [HybrisContextFactory] Loading <<application>> spring config <master> from extension (core) located in (core-spring.xml,persistence-spring.xml,core-media-spring.xml,core-profiling-spring.xml,core-jmx-spring.xml,core-filter-spring.xml,servicelayer-spring.xml,user-spring.xml,security-spring.xml,media-spring.xml,i18n-spring.xml,interceptor-spring.xml,event-spring.xml) took: (163.4 ms)
各种Bean的加载:
clipboard9,9
启动indexer cronjob:
clipboard10,10
各种Spring post processing操作:
clipboard11,11
[32mINFO [localhost-startStop-3] (junit) [MapMergeDirectiveBeanPostProcessor] Post Processing MapMergeDirective [defaultPromotionProductRaoProvidersMapping] on Bean [raoProviders]
[m[32mINFO [localhost-startStop-3] (junit) [MapMergeDirectiveBeanPostProcessor] Post Processing MapMergeDirective [defaultCouponRuleActionMetadataHandlersMergeDirective] on Bean [ruleActionMetadataHandlers]
[m[32mINFO [localhost-startStop-3] (junit) [MapMergeDirectiveBeanPostProcessor] Post Processing MapMergeDirective [givenCouponActionStrategiesMappingMergeDirective] on Bean [promotionActionStrategiesMapping]
[m[32mINFO [localhost-startStop-3] (junit) [ListMergeDirectiveBeanPostProcessor] Post Processing ListMergeDirective [commerceQuoteCartCalculationMethodHookMergeDirective] on Bean [commerceCartCalculationMethodHooks]
[m[32mINFO [localhost-startStop-3] (junit) [ListMergeDirectiveBeanPostProcessor] Post Processing ListMergeDirective [commerceAddToCartProductConfigMergeDirective] on Bean [commerceAddToCartMethodHooks]
[m[32mINFO [localhost-startStop-3] (junit) [MapMergeDirectiveBeanPostProcessor] Post Processing MapMergeDirective [textFieldConfigurationHandlerRegistrar] on Bean [productConfigurationHandlers]
[m[32mINFO [localhost-startStop-7] [RemoveDefaultSessionFixationStrategyBeanPostProcessor] Spring default SessionFixationProtectionStrategy was not defined. Added HybrisSessionFixationProtectionStrategy
