☆打卡算法☆LeetCode 37、解数独 算法解析
恬静的小魔龙 发表于 2022/01/27 14:56:47 2022/01/27
【摘要】 推荐阅读CSDN主页GitHub开源地址Unity3D插件分享简书地址我的个人博客QQ群:1040082875大家好,我是小魔龙,Unity3D软件工程师,VR、AR,虚拟仿真方向,不定时更新软件开发技巧,生活感悟,觉得有用记得一键三连哦。 一、题目 1、算法题目“编写程序,填写数独剩余空格,解数独。”题目链接:来源:力扣(LeetCode)链接:37. 解数独 - 力扣(LeetCode)...
推荐阅读
一、题目
1、算法题目
题目链接:
来源:力扣(LeetCode)
链接:37. 解数独 - 力扣(LeetCode) (leetcode-cn.com)
2、题目描述
编写一个程序,通过填充空格来解决数独问题。
数独的解法需 遵循如下规则:
  • 数字 1-9 在每一行只能出现一次。
  • 数字 1-9 在每一列只能出现一次。
  • 数字 1-9 在每一个以粗实线分隔的 3x3 宫内只能出现一次。(请参考示例图)
    数独部分空格内已填入了数字,空白格用 ‘.’ 表示。
示例图:
示例 1:
输入:board = [["5","3",".",".","7",".",".",".","."],["6",".",".","1","9","5",".",".","."],[".","9","8",".",".",".",".","6","."],["8",".",".",".","6",".",".",".","3"],["4",".",".","8",".","3",".",".","1"],["7",".",".",".","2",".",".",".","6"],[".","6",".",".",".",".","2","8","."],[".",".",".","4","1","9",".",".","5"],[".",".",".",".","8",".",".","7","9"]]
输出:[["5","3","4","6","7","8","9","1","2"],["6","7","2","1","9","5","3","4","8"],["1","9","8","3","4","2","5","6","7"],["8","5","9","7","6","1","4","2","3"],["4","2","6","8","5","3","7","9","1"],["7","1","3","9","2","4","8","5","6"],["9","6","1","5","3","7","2","8","4"],["2","8","7","4","1","9","6","3","5"],["3","4","5","2","8","6","1","7","9"]]
解释:输入的数独如上图所示,唯一有效的解决方案如下所示:
二、解题
1、思路分析
这个题考虑按行解题的顺序,通过递归+回溯枚举所有可能的填法,当递归到最后的时候,仍然是合理的答案,说明我们找到了答案。
在递归的过程中,发现当前格子不能填下任何一个数字,那么就进行回溯。
2、代码实现
代码参考:
public class Solution
    //九列
    List<Dictionary<int, bool>> liCol = new List<Dictionary<int, bool>>();
    //九行
    List<Dictionary<int, bool>> liRow = new List<Dictionary<int, bool>>();
    //3*3格子 九个
    List<Dictionary<int, bool>> liBox = new List<Dictionary<int, bool>>();
    char[][] boardAllres = null;
    public void SolveSudoku(char[][] board)
        //判断一共有多少个数字
        int hasNumCount = 0;
        Dictionary<int, bool> dicAllTemp = new Dictionary<int, bool>();
        //创建一个键值对集合存储数字是否出现过
        for (int i = 1; i <= 9; i++)
            dicAllTemp.Add(i, false);
        for (int i = 0; i < 9; i++)
            //存储对应的九列
            liCol.Add(new Dictionary<int, bool>(dicAllTemp));
            //存储对应的九行
            liRow.Add(new Dictionary<int, bool>(dicAllTemp));
            //存储对应的九个3*3格子
            liBox.Add(new Dictionary<int, bool>(dicAllTemp));
        //遍历整个集合 将已出现的数字赋值为true
        for (int i = 0; i < board.Length; i++)
            for (int j = 0; j < board[0].Length; j++)
                if (board[i][j] != '.')
                    int temp =  board[i][j]-48;
                    liRow[i][temp] = true;
                    liCol[j][temp] = true;
                    int count = (i / 3)*3 + j / 3;
                    liBox[count][temp] = true;
                    hasNumCount++;
        Recursive(board, hasNumCount, 0, 0);
        board= boardAllres;
    public bool Recursive(char[][] board, int hasNumCount,int i,int j)
        //81个数字代表已经填满了 直接返回结果
        if (hasNumCount==81)
            boardAllres = board;
            return true;
        for (; i < board.Length; i++)
            for (j=0; j < board[0].Length; j++)
                if (board[i][j] == '.')
                    //查出该行对应的所有未使用的数字 一次遍历填入
                    List<int> liRes = liRow[i].Where(e => e.Value == false).Select(e => e.Key).ToList();
                    foreach (var item in liRes)
                        //判读位于那个格子
                        int count = (i / 3) * 3 + j / 3;
                        if (liCol[j][item] == false && liBox[count][item] == false && liRow[i][item] == false)
                            //总数+1 对应的位置赋值为true
                            hasNumCount++;
                            liRow[i][item] = true;
                            liCol[j][item] = true;
                            liBox[count][item] = true;
                            //之所以加48为了将数字转为char类型存进去
                            board[i][j] =(char)(item+48);
                            //递归 存在不符合就返回 结果为true只有一种情况 那就是已经完成了
                            if (Recursive(board, hasNumCount, i, 0))
                                return true;
                            //不符合 将操作撤回到之前
                            hasNumCount--;
                            board[i][j] = '.';
                            liRow[i][item] = false;
                            liCol[j][item] = false;
                            liBox[count][item] = false;
                    return false;
        return false;
3、时间复杂度
时间复杂度 :
空间复杂度:
三、总结
遍历过程之后,进行递归和回溯枚举,这个还是很难的。
要思考好边界问题,还有回溯到当前递归层时,其他变量的复原问题。
