Leetcode 题目解析之 Valid Anagram
ruochen 发表于 2022/01/24 15:58:33 2022/01/24
【摘要】 Leetcode 题目解析之 Valid Anagram
Given two strings s and t, write a function to determine if t is an anagram of s.
For example,
s = “anagram”, t = “nagaram”, return true.
s = “rat”, t = “car”, return false.
Note:
You may assume the string contains only lowercase alphabets.
Follow up:
What if the inputs contain unicode characters? How would you adapt your solution to such case?
用数组模拟哈希表,统计字符出现次数。
    public boolean isAnagram(String s, String t) {
        if (s == null || t == null) {
            return false;
        if (s.length() != t.length()) {
            return false;
        if (s.equals(t)) {
            return false;
        int len = s.length();
        int[] map = new int[26];
        // 统计s中每个字符出现的次数
        for (int i = 0; i < len; i++) {
            map[s.charAt(i) - 'a']++;
        // 减去t中相应字符出现次数
            map[t.charAt(i) - 'a']--;
            if (map[t.charAt(i) - 'a'] < 0) {
                return false;
        for (int i = 0; i < 26; i++) {
            if (map[i] != 0) {
                return false;
        return true;
