Leetcode 题目解析之 Single Number II
ruochen 发表于 2022/01/24 15:58:02 2022/01/24
【摘要】 Leetcode 题目解析之 Single Number II
Given an array of integers, every element appears three times except for one. Find that single one.
Note:
Your algorithm should have a linear runtime complexity. Could you implement it without using extra memory?
对于数组{1,1,1,2}来说,分析每一位:
0 0 0 1
0 0 0 1
0 0 0 1
0 0 1 0
0 0 1 3 (位数)
可以分析,分别计算每一位1的出现次数n,如果n%3==1,那么结果中这一位就应该是1。
    public int singleNumber(int[] nums) {
        int rt = 0, bit = 1;
        for (int i = 0; i < 32; i++) {
            int count = 0;
            for (int v : nums) {
                if ((v & bit) != 0) {
                    count++;
            bit <<= 1;
            rt |= (count % 3) << i;
        return rt;
