ValueError: cannot encode objects that are not 2-tuples
irrational 发表于 2022/01/23 02:06:26 2022/01/23
【摘要】 ValueError: cannot encode objects that are not 2-tuples The code: import requests from StringIO impo...
The code:
import requests
from StringIO import StringIO
buffer = StringIO()
url = 'http://example.com/files/'
user, password = 'ex', 'ample'
buffer.write(open(r'C:\Users\example\Desktop\code\de.txt','rb').read())
r = requests.post(url,  auth=(user, password), files=buffer.getvalue())
修改办法:
files only accepts a dictionary or sequence of (key, value) tuples. Give your file field a name:
r = requests.post(url,  auth=(user, password), files={'file': buffer.getvalue()})
文章来源: blog.csdn.net,作者:irrationality,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_54227557/article/details/122619469
评论(0
