扫雷python实现
野猪佩奇996 发表于 2022/01/23 00:06:55 2022/01/23
【摘要】 global_var.py #全局变量 tablemaps = [] gamemaps = [] 123 saolei.py文件 import random import global_var as...
global_var.py
#全局变量
tablemaps = []
gamemaps = []
saolei.py文件
import random
import global_var as gl
# # 计算雷数
def mine_num(line, col):
    mineNum = 0
    # 计算周围8个格子
    if line - 1 >= 0 and col - 1 >= 0:
        mineNum += gl.tablemaps[line - 1][col - 1]
    if line - 1 >= 0:
        mineNum += gl.tablemaps[line - 1][col]
    if line - 1 >= 0 and col + 1 < 9:
        mineNum += gl.tablemaps[line - 1][col + 1]
    if col - 1 >= 0:
        mineNum += gl.tablemaps[line][col - 1]
    if col + 1 < 9:
        mineNum += gl.tablemaps[line][col + 1]
    if line + 1 < 9 and col - 1 >= 0:
        mineNum += gl.tablemaps[line + 1][col - 1]
    if line + 1 < 9:
        mineNum += gl.tablemaps[line + 1][col]
    if line + 1 < 9 and col + 1 < 9:
        mineNum += gl.tablemaps[line + 1][col + 1]
    return mineNum
def create_mine():
    gl.gamemaps = [['?'] * 9 for i in range(9)]
    gl.tablemaps = [[0] * 9 for i in range(9)]
    for i in range(15):
        x = random.randrange(0, 9)
        y = random.randrange(0, 9)
        if gl.tablemaps[x][y] == 0:
            gl.tablemaps[x][y] = 1
        else:
            x = random.randrange(1, 8)
            y = random.randrange(1, 8)
    # 展示雷分布的图 注释掉可隐藏
    for a in range(9):
        print(gl.tablemaps[a])
def create_table():
    for line in range(9):
        if line == 0:
            print("   0  1  2  3  4  5  6  7  8")
        for column in range(9):
            if column == 0:
                print(line, end="  ")
            print(gl.gamemaps[line][column], end="  ")
        print("")
    print("输入例如:0,0,s 表示安全")
    print("输入例如:0,0,c 表示插旗子")
    print("输入例如:0,0,d 表示拔旗子")
def checkvictory():
            if gl.gamemaps[line][column] == '?':
                return False
    return True
def base_count(line, col):
    mineNum = 0
    mineNum = mine_num(line, col)
    if mineNum == 0:
        gl.gamemaps[line][col] = ' '
        main_count(line, col)
    else:
        gl.gamemaps[line][col] = mineNum
# 计算九宫格
def main_count(line, col):
    # 计算周围8个格子
    if line - 1 >= 0 and col - 1 >= 0 and gl.gamemaps[line - 1][col - 1] == "?":
        base_count(line - 1, col - 1)
    if line - 1 >= 0 and gl.gamemaps[line - 1][col] == "?":
        base_count(line - 1, col)
    if line - 1 >= 0 and col + 1 < 9 and gl.gamemaps[line - 1][col + 1] == "?":
        base_count(line - 1, col + 1)
    if col - 1 >= 0 and gl.gamemaps[line][col - 1] == "?":
        base_count(line, col - 1)
    if col + 1 < 9 and gl.gamemaps[line][col + 1] == "?":
        base_count(line, col + 1)
    if line + 1 < 9 and col - 1 >= 0 and gl.gamemaps[line + 1][col - 1] == "?":
        base_count(line + 1, col - 1)
    if line + 1 < 9 and gl.gamemaps[line + 1][col] == "?":
        base_count(line + 1, col)
    if line + 1 < 9 and col + 1 < 9 and gl.gamemaps[line + 1][col + 1] == "?":
        base_count(line + 1, col + 1)
if __name__ == '__main__':
    create_mine()
    while True:
        create_table()
        operation = input("请输入:")
        temp = operation.split(',')
        if str(operation) == "r":
            create_mine()
            continue
        elif str(operation) == "e":
            break
        if len(temp) != 3:
            print("输入格式有误请重新输入!")
            continue
        # 掀开
        if str(temp[2]) == "s":
            if gl.gamemaps[int(temp[0])][int(temp[1])] == "?":
                if gl.tablemaps[int(temp[0])][int(temp[1])] == 0:
                    mineNum = mine_num(int(temp[0]), int(temp[1]))
                    if mineNum != 0:
                        gl.gamemaps[int(temp[0])][int(temp[1])] = mineNum
                    else:
                        main_count(int(temp[0]), int(temp[1]))
                    if checkvictory():
                        print("恭喜胜利")
                        a = input("输入r重新开始,输入e退出。")
                        if a == "r":
                            create_mine()
                        elif a == "e":
                            break
                        else:
                            print("输入错误请重新输入")
                elif gl.tablemaps[int(temp[0])][int(temp[1])] == 1:
                    print("-------失败,将重新开始------")
                    if a == "r":
                        create_mine()
                    elif a == "e":
                        break
                    else:
                        print("输入错误请重新输入")
            else:
                print("此处不能掀开")
        # 插旗
        elif temp[2] == "c":
                gl.gamemaps[int(temp[0])][int(temp[1])] = "*"
                if checkvictory():
                    print("恭喜胜利")
                    if a == "r":
                        create_mine()
                    elif a == "e":
                        break
                    else:
                        print("输入错误请重新输入")
            else:
                print("此处不能插旗")
        # 拔旗
        elif temp[2] == "d":
            if gl.gamemaps[int(temp[0])][int(temp[1])] == "*":
                gl.gamemaps[int(temp[0])][int(temp[1])] = "?"
            else:
                print("此处没有旗子")
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
文章来源: andyguo.blog.csdn.net,作者:山顶夕景,版权归原作者所有,如需转载,请联系作者。
原文链接:andyguo.blog.csdn.net/article/details/116357824
