如何解决error: failed to push some refs to 'xxx(远程库)'
孙中明 发表于 2022/01/22 23:38:09 2022/01/22
【摘要】 如何解决error: failed to push some refs to ‘xxx(远程库)’ 在使用 Android Studio 对源代码进行push到码云时可出错,报错如下: 15:55:0...
15:55:01.129: [fuwandai] git -c core.quotepath=false push --progress --porcelain origin refs/heads/master:master --set-upstream
error: failed to push some refs to 'https://gitee.com/dapanjimianpaigumian/FirstProject.git'
To https://gitee.com/dapanjimianpaigumian/FirstProject.git
!	refs/heads/master:refs/heads/master	[rejected] (fetch first)
hint: Updates were rejected because the remote contains work that you do
hint: not have locally. This is usually caused by another repository pushing
Done
hint: to the same ref. You may want to first integrate the remote changes
hint: (e.g., 'git pull ...') before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
出现错误的主要原因是oschina中的README.md文件不在本地代码目录中
可以通过如下命令进行代码合并【注:pull=fetch+merge]
git pull --rebase origin master
执行上面代码后可以看到本地代码库中多了README.md文件
此时再执行语句 git push -u origin master即可完成代码上传到oschina
原文链接:https://blog.csdn.net/zhao_xin_peng/article/details/79378895
文章来源: hiszm.blog.csdn.net,作者:孙中明,版权归原作者所有,如需转载,请联系作者。
原文链接:hiszm.blog.csdn.net/article/details/104043055
