Leetcode 题目解析之 Fraction to Recurring Decimal
ruochen 发表于 2022/01/22 21:57:07 2022/01/22
【摘要】 Leetcode 题目解析之 Fraction to Recurring Decimal
Given two integers representing the numerator and denominator of a fraction, return the fraction in string format.
If the fractional part is repeating, enclose the repeating part in parentheses.
For example,
  • Given numerator = 1, denominator = 2, return “0.5”.
  • Given numerator = 2, denominator = 1, return “2”.
  • Given numerator = 2, denominator = 3, return “0.(6)”.
    public String fractionToDecimal(int numerator, int denominator) {
        String sign = "";
        if (Math.signum(numerator) * Math.signum(denominator) < 0) {
            sign = "-";
        long n = Math.abs(numerator);
        long d = Math.abs(denominator);
        String intPart = Math.abs(n / d) + "";
        // 如果整除,直接返回结果
        if (n % d == 0) {
            return sign + intPart;
        // 计算小数部分
        n %= d;
        n *= 10;
        StringBuilder sb = new StringBuilder();
        Map<Long, Integer> mod = new HashMap<Long, Integer>();
        for (int i = 0; n != 0; i++) {
            long q = n / d;
            Integer start = mod.get(n / 10);
            if (start != null) {
                sb.insert(start, "(");
                sb.append(")");
                break;
            sb.append(Math.abs(q));
            mod.put(n / 10, i);
            n %= d;
            n *= 10;
        String fractionalPart = sb.toString();
        return sign + intPart + "." + fractionalPart;
