Leetcode 题目解析之 Search for a Range
ruochen 发表于 2022/01/22 21:48:50 2022/01/22
【摘要】 Leetcode 题目解析之 Search for a Range
Given a sorted array of integers, find the starting and ending position of a given target value.
Your algorithm’s runtime complexity must be in the order of O(log n).
If the target is not found in the array, return -1, -1.
For example,
Given 5, 7, 7, 8, 8, 10 and target value 8,
return 3, 4.
    public int[] searchRange(int[] nums, int target) {
        int l = 0, r = nums.length;
        while (l < r) {
            int m = l + (r - l) / 2;
            if (nums[m] == target) {
                int s = m, e = m;
                while (s - 1 >= 0 && nums[s - 1] == target) {
                    s--;
                while (e + 1 < nums.length && nums[e + 1] == target) {
                    e++;
                return new int[] { s, e };
            } else if (nums[m] > target) {
                r = m;
                l = m + 1;
        return new int[] { -1, -1 };
