PHP面试题:单例模式,创建mysqli数据库链接的单例对象
红目香薰 发表于 2022/01/21 23:58:46 2022/01/21
【摘要】 class Db { private static $instance; public $handle; Private function __construct($host,$username,$password,$dbname) { $this->handle=NULL; $this->getcon($ho...
  1. class Db {
  2. private static $instance;
  3. public $handle;
  4. Private function __construct($host,$username,$password,$dbname) {
  5. $this->handle=NULL;
  6. $this->getcon($host,$username,$password,$dbname);
  7. }
  8. public static function getBb() {
  9. self::$instance=new Db();
  10. return self::$instance;
  11. }
  12. private function getcon($host,$username,$password,$dbname) {
  13. if($this->handle!=NULL){
  14. return true;
  15. }
  16. $this->handle=mysqli_connect($host,$username,$password,$dbname);
  17. }
  18. }
文章来源: laoshifu.blog.csdn.net,作者:红目香薰,版权归原作者所有,如需转载,请联系作者。
原文链接:laoshifu.blog.csdn.net/article/details/115221870
