分布式专题——Reactive访问Spring Data Redis
小白弟弟 发表于 2022/01/21 23:53:42 2022/01/21
【摘要】 @[TOC] 1、定义Lettuce 能够⽀持 Reactive ⽅式Spring Data Redis 中主要的⽀持ReactiveRedisConnectionReactiveRedisConnectionFactoryReactiveRedisTemplateopsForXxx() 2、pom<?xml version="1.0" encoding="UTF-8"?><project ...
@[TOC]
1、定义
  • ReactiveRedisConnection
  • ReactiveRedisConnectionFactory
  • ReactiveRedisTemplate
    • opsForXxx()
2、pom
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.1.3.RELEASE</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.zhz</groupId>
    <artifactId>reactive-spring-boot-reactive-redis-demo</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>reactive-spring-boot-reactive-redis-demo</name>
    <description>Spring Boot中的reactive集成redis</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-data-redis-reactive</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-jdbc</artifactId>
        </dependency>
        <dependency>
            <groupId>com.h2database</groupId>
            <artifactId>h2</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
            <optional>true</optional>
        </dependency>
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
3、yml
spring:
  datasource:
    url: jdbc:mysql://119.29.36.141:3306/spring-test?serverTimezone=GMT%2B8
    username: root
    password: root
    hikari:
      connection-test-query: SELECT 1
      connection-timeout: 60000
      idle-timeout: 500000
      max-lifetime: 540000
      maximum-pool-size: 12
      minimum-idle: 10
      pool-name: GuliHikariPool
  output:
    ansi:
      enabled: always
  redis:
    host: localhost
    port: 6379
    password: 123456
management:
  endpoints:
    web:
      exposure:
        include: '*'
mybatis:
  type-handlers-package: com.zhz.springbootmybatisdemo.handler
  configuration:
    map-underscore-to-camel-case: true
4、实体类
package com.zhz.reactive;
import lombok.AllArgsConstructor;
import lombok.Builder;
import lombok.Data;
import lombok.NoArgsConstructor;
@Data
@Builder
@NoArgsConstructor
@AllArgsConstructor
public class Coffee {
    private Long id;
    private String name;
    private Long price;
5、测试类
import lombok.extern.slf4j.Slf4j;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.boot.ApplicationArguments;
import org.springframework.boot.ApplicationRunner;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.context.annotation.Bean;
import org.springframework.data.redis.connection.ReactiveRedisConnectionFactory;
import org.springframework.data.redis.core.ReactiveHashOperations;
import org.springframework.data.redis.core.ReactiveRedisTemplate;
import org.springframework.data.redis.core.ReactiveStringRedisTemplate;
import org.springframework.jdbc.core.JdbcTemplate;
import reactor.core.publisher.Flux;
import reactor.core.publisher.Mono;
import reactor.core.scheduler.Schedulers;
import java.time.Duration;
import java.util.List;
import java.util.concurrent.CountDownLatch;
@Slf4j
@SpringBootApplication
public class ReactiveSpringBootReactiveRedisDemoApplication implements ApplicationRunner {
    private static final String KEY = "COFFEE_MENU";
    @Autowired
    private JdbcTemplate jdbcTemplate;
    @Autowired
    private ReactiveStringRedisTemplate reactiveStringRedisTemplate;
        SpringApplication.run(ReactiveSpringBootReactiveRedisDemoApplication.class, args);
    @Bean
    public ReactiveStringRedisTemplate reactiveRedisTemplate(ReactiveRedisConnectionFactory reactiveRedisConnectionFactory) {
        return new ReactiveStringRedisTemplate(reactiveRedisConnectionFactory);
    @Override
    public void run(ApplicationArguments args) throws Exception {
        ReactiveHashOperations<String, String, String> hashOperations = reactiveStringRedisTemplate.opsForHash();
        CountDownLatch countDownLatch = new CountDownLatch(1);
        List<Coffee> coffees = jdbcTemplate.query("select * from t_coffee", (rs, i) ->
                Coffee.builder()
                        .id(rs.getLong("id"))
                        .name(rs.getString("name"))
                        .price(rs.getLong("price"))
                        .build()
        Flux.fromIterable(coffees)
                .publishOn(Schedulers.single())
                .doOnComplete(() -> log.info("查询完毕"))
                .flatMap(c -> {
                    log.info("try to put {},{}", c.getName(), c.getPrice());
                    return hashOperations.put(KEY, c.getName(), c.getPrice().toString());
                .concatWith(reactiveStringRedisTemplate.expire(KEY, Duration.ofMinutes(1)))//1分钟
                .doOnComplete(() -> log.info("expire ok"))
                .onErrorResume(e -> {
                    log.error("exception {}", e.getMessage());
                    return Mono.just(false);
                .subscribe(b -> log.info("Boolean: {}", b),
                        e -> log.error("Exception {}", e.getMessage()),
                        () -> countDownLatch.countDown());
        log.info("Waiting");
        countDownLatch.await();
