含sql_identifier 字段analyze表告警分析
jl3036 发表于 2022/01/20 17:13:18 2022/01/20
【摘要】 问题表象:表analyze时 提示告警 the tupleDesc analyzed in coordinator is different from tupleDesc which received from datanode。问题分析:本地测试,创建测试表create table t3(id information_schema.sql_identifier, c1 informatio...
问题表象:
问题分析:
本地测试,创建测试表
create table t3(id information_schema.sql_identifier, c1 information_schema.sql_identifier, c2 text);
insert into t3 values (1, 1, 1);
对t3表做表分析
提示信息WARNING:  The tupleDesc analyzed in coordinator is different from tupleDesc which received from datanode.
HINT:  Do analyze again for the relation: t3
原因分析:
数据库中dn传上来的类型时1043, 就是varchar,和cn上的不一致
select oid, typname, typbasetype from pg_type where typname = 'sql_identifier';
规避措施:尽量使用字符串来替换sql_identifier 类型
