Leetcode 题目解析之 Search a 2D Matrix
ruochen 发表于 2022/01/14 13:55:06 2022/01/14
【摘要】 Leetcode 题目解析之 Search a 2D Matrix
Write an efficient algorithm that searches for a value in an m x n matrix. This matrix has the following properties:
  • Integers in each row are sorted from left to right.
  • The first integer of each row is greater than the last integer of the previous row.
    For example,
Consider the following matrix:
1, 3, 5, 7,
10, 11, 16, 20,
23, 30, 34, 50
    public boolean searchMatrix(int[][] matrix, int target) {
        int mx = matrix.length;
        int my = matrix[0].length;
        int l = 0;
        int r = mx * my;
        while (l < r) {
            int m = l + (r - l) / 2;
            // 将m转换成x、y
            int x = m / my;
            int y = m % my;
            // 二分查找:matrix[x][y]转换成一维数组,坐标就是m
            if (matrix[x][y] == target) {
                return true;
            } else if (matrix[x][y] < target) {
                l = m + 1;
                r = m;
        return false;
