Leetcode 题目解析之 Rotate Array
ruochen 发表于 2022/01/14 13:54:07 2022/01/14
【摘要】 Leetcode 题目解析之 Rotate Array
Rotate an array of n elements to the right by k steps.
For example, with n = 7 and k = 3, the array 1,2,3,4,5,6,7 is rotated to 5,6,7,1,2,3,4.
Note:
Try to come up as many solutions as you can, there are at least 3 different ways to solve this problem.
show hint
Hint:
Could you do it in-place with O(1) extra space?
Related problem: Reverse Words in a String II
    void reverse(int[] nums, int st, int ed) {
        while (st < ed) {
            int t = nums[st];
            nums[st] = nums[ed];
            nums[ed] = t;
            st++;
            ed--;
    public void rotate(int[] nums, int k) {
        int length = nums.length;
        k = k % length;
        if (length == 1 || k == 0)
            return;
        reverse(nums, 0, length - k - 1);
        reverse(nums, length - k, length - 1);
        reverse(nums, 0, length - 1);
